Old 12-22-2006, 12:26 PM
Hive Guy Hive Guy is offline
Default DAE Error 7101 and 7100 on Mix system
I'm hoping someone can help out with this problem:
My rig: Mix Core, 2 Mix Farms, 1 dsp Farm. G4 733 maxed RAM, OSX 10.3.9, PT 6.4.1cs4. All cards pass Digitest.
This morning I installed some Steven Massey demos (L2007, VT-3, THC, Tapehead). As part of the THC installation, it was recommended to install the Digi EQ III plugin.
I know this is not supported for my system, but it is supposed to work as RTAS.
Since then, when I am running sessions with 64 voices/2 DSPs, the system will not shuffle DSP when trying to add a plug that requires it and gives me DAE error #7100, or #7101. Additionally, whenever closing a session, PT crashes.
I've ditched all the Digi Databases and Volumes a few times, ran Digitest (passes), removed all the Massey plugs, and EQ III. Restarted computer and all hardware. I believe that I had PT 6.4.1cs3 running, I downloaded and installed cs4 to see if it would help. Problem still occurs.
I'm considering re-installing Protools. However, I believe that EQ III installs some stuff that must be removed manually. Could someone fill me in on this? (I tried searching the DUC and Digi's site but couldn't find what I wanted).
Anyone have some advice?
Thanks.
Error "-4" and 7100+ 7058 with MDW EQ on HD system groovebrother Pro Tools TDM Systems (Mac) 7 10-05-2007 10:27 AM
dae error 7101 with pt5.1.1 on win2k bigdude Pro Tools TDM Systems (Win) 3 07-23-2001 11:47 AM
Error -7101 multi track record SOR Pro Tools TDM Systems (Mac) 1 06-11-2001 05:07 AM
DAE error was encountered while trying to connect (error #-7101 Enis Presheva Jr. Pro Tools TDM Systems (Mac) 1 06-07-2001 12:45 AM
DAE Error 7101 GS-DK Pro Tools TDM Systems (Mac) 5 01-28-2001 02:38 PM
