TC Electronic Powercore compact and -9073 error
I recently upgraded to a G5 1.8ghz tower and version 7.1LE, prior I was running 7.0 on an Imac. I have 3 FW external drives that I use and I have noticed since the upgrade I have been getting this error quite a bit and it has to be the Powercore. I am not sure why, it ran without any issues on 7.0 with the imac.
I have done all the troubleshooting on this and am not quite sure what else to do. Has anyone else had an issue with this?
www.klearlightstudio.com |
Re: TC Electronic Powercore compact and -9073 erro
Even after my Powercore compact is removed from the system completely this is still happening. I have done every troubleshoot related to this the I can think of and all my drives are qualified. I am really at a loss on this one, any help would be greatly appreciated.
This may be redundant, but have you turned journaling off for every one of your drives?
Well, I don't have journaling off, but Digi says that you should have journaling enabled now. I do have the spolight indexing turned off on these drives.
Do you have the drives chained? Have tried using the front firewire port? I have to say firewire issues are common on the G5s and your best bet may be to try a PCI firewire setup.
jimmy 15" Macbook Pro R 2.6 i7 Quad/16GB RAM/OS X 10.10.5 27" iMac 2.8 i7 Quad/16GB RAM/OS X 10.10.5 Studio One 3/Reason 8/Live 9/Logic Pro 9/Main Stage 3 |
Really, I do have a FW PCI card that I just installed. I was trying to figure out if the card or Powercore were causing these issues. When both were removed the problem still occured. Do you think if I run everyting through the PCI card the issued should be resolved? That is one thing I have not tried.
I would give it a shot. I had 3 different G5s and always had issues with the firewire buss--they are all on the same buss. I had better luck with a firewire PCI card--it was one of the cards Digi approves in the Compato Docs. Again some people have the best luck with the front firewire port.
what card did you get? I have an adaptec.
Thanks a lot, I just picked up the ADS for $34.99 at Circuit City. If this works I will be happy man!!
tc electronics Powercore Compact | Hank S. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-06-2006 02:02 AM |
Pro Tools LE and TC Powercore compact | indoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-02-2006 06:38 PM |
TC PowerCore compact RTAS/VST | hzd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-26-2005 09:22 AM |
TC Electronic Powercore | svphk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-24-2004 07:11 AM |
PowerCore Firewire and Compact | tele_player | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-12-2004 04:13 PM |
