Re: Pt10hd with allen & heath gs24r
Albee - great
I know I definitely have HD software not just 10 so therefore I am happy. I understand I will have no TDM (no problem) and my IO will be limited to 32 (no problem) Input latency should not be a problem as I will be using it in connection with an analogue desk so can set up no latency monitoring. I also have a powerful computer so all should be fine there too. Many thanks I will try booting up with the N key tonight just to check it will run ok without the HD hardware connected. I take it I don't have to actually physically remove the HD cards to try this? Ian |
Nope. Leave the cards in. When you select a different "audio engine" you will be telling PT to ignore the cards and use something else(like CORE audio).
Tried opening while holding down n key and it brings up audio engine but does not give me the option to change anything except hardware buffer etc? Why would this be? Could it be because I do not have core audio installed? Does this not get installed automatically when you install protools?
Sorted it asio4all did the trick !!
Allen and Heath ZED 24 | mrjames | Pro Tools 10 | 3 | 05-03-2012 02:23 PM |
Will PT9 work with a Allen & Heath Z14? | Jwhitehead333 | macOS | 4 | 05-03-2012 11:52 AM |
Allen & Heath ZED R16 with PT9 and OSX10.5 | jeanpauldubock | macOS | 4 | 09-26-2011 10:31 PM |
allen and heath gs 3 | mersisblue | Tips & Tricks | 6 | 09-01-2003 08:50 PM |
Allen & Heath GS2 with 001 | Keith Lowdon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-19-2002 09:51 AM |
