Inserts affecting send meter but not channel meter?
In the past, if i load a compressor plugin on a channel insert and boost the Comp's output, it affects the main channel meter even causing it to clip (once i find a suitable setting). In my current session, if i load a comp on an insert and crank the comp output, the DAW meter is unaffected, yet, if I create a send on the same channel, the return meter that pops up is clipping like crazy and stops if i remove the comp insert.
i admit im a bit of a noob when it comes to signal routing but what the heck is going on here and how SHOULD things be happening here? |
Re: Inserts affecting send meter but not channel meter?
Bug. The bussing in PT9 has a few glitches that show up sporadically. They're pretty rare, thankfully. Closing and reopening the session usually straightens things out. If not, quit and relaunch PT. If that doesn't fix it, I don't know what to tell you.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Seeing only one send and its meter | SickTheory | Windows | 2 | 09-24-2012 04:34 AM |
My LOUD beat clips all my inserts plugins and Vu-Meter! | chavernac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-27-2010 08:09 PM |
Send Output Meter shows track level? | lwilliam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-22-2009 07:05 PM |
PTHD8 cpu meter vs task manager cpu meter | MEAT | Pro Tools TDM Systems (Win) | 5 | 01-02-2009 05:17 AM |
channel level mirrored in send level meter | daveh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-01-2001 01:32 AM |
