Re: I/O Setup gets jumbled up/corrupted
You can send them to : vi [at] digidesign [dot] com. Please put the thread number in the subject of the email. Thanks! |
Can you acknowledge that you guys are aware of the default output setting not sticking when you close and re-open the session bug. Thanks.
Obviously we've got this logged and will address it as soon as possible - when, I can't say for sure, as there's a lot going on at the moment here at Avid... |
I'm on PT11 HD 11.2.2 and am experiencing the jumbled I/O problem. Seems to happen only when I switch sessions. Once I re-do the mappings it stays fixed as long as I continue to work on the same session each day.
What is the status from AVID on this problem? If it was fixed at PT12, is there some kind of workaround I can use to avoid the problem until I move to the higher release? |
Audio Midi Setup corrupted in ML? | stigc56 | macOS | 2 | 03-10-2013 03:07 PM |
Setup file for M powered Essential corrupted? | Billkingvo | Pro Tools SE and Essential (Win) | 0 | 12-31-2011 01:30 PM |
MIDI is jumbled | chipper3344 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-10-2007 11:32 AM |
Jumbled recording | bad1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-03-2004 10:18 AM |
Jumbled Digital Video | storymaster2k | Pro Tools TDM Systems (Mac) | 0 | 08-25-2003 03:58 PM |
