Having issues with LtRt downmix
I'm currently downmixing a documentary from 5.1 to LtRt using Neyrinck SoundCode with the PL2 Encoder. (I haven't done this encoding myself before)
The downmix sounds good but I'm not so happy with the decoded 5.1 version. When decoded, pretty much all the channels are all smeared together a bit. Music is bleeding into the centre from the L and R. Dialog and Narration are bleeding into the LR a bit, and it sounds phasey. I don't know if this is pretty standard for decoded LtRt or if I'm messing something up. If not, are there some ways to improve the decoded outcome? |
Re: Having issues with LtRt downmix
Matrixed surround is always a compromise, and you will never get an Lt/Rt downmix to sound as good as the original 5.1 discrete mix when run through anything, and with DPL II your settings are critical to standing a chance.
Can you please tell me what your DPL II settings are?
XI-machines PC-DAW with Intel Xeon E5-2687W CPU (8/16 cores at 3.1GHz/core), 32GB RAM, AMD Radeon R7 200 Graphics, RME RayDAT I/O > RME ADI-8 DS Pro ADC/DAC, Waves DigiGrid IOS (ethernet), Adam Audio A7x 5.1 system. NetStor TurboBox c/w 3x UAD-2 Octo DSP, Steinberg Nuendo 10.2 & Cubase Pro 10.5 c/w WK Audio ID Remote Mixing Console. Plug-ins & ancillaries (full libraries unless stated) AA Translator, GEAR Pro Mastering Edition, Scenarist SD/BD/BD-J, MEI DVD-Audio Creator, DVD-Lab Pro 2 Universal Audio, Plugin Alliance, Eventide, Waves, Sonnox, Zynaptiq, Softube*, iZotope*, Voxengo*, Flux*, Slate Digital*, PSP Audioware* and many more * = selected tools only (full list available on request) |
LtRt should be retired IMHO.
It was a technology for a time when bandwidth wasn't available/ allotted for discreet surround channels. Not only is the decoded signal often unsatisfying in surround, but it also to my ears makes the encoded stereo version lack definition. It was great and clever for its time. I don't see it being asked for so much on deliverables any more thankfully. I hope it will gradually disappear.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
LR=0 C=-3 LSRS=-6 LFE=-3 |
No one is asking for LTRT anymore. Im down mixing LoRo for the 2 channel mix.
IMDB |
Just starting a series for Disney Channel. The abc cable networks spec they sent me still has a LtRt as the 2 channel mix needed along with the 5.1. I queried it but they said it’s required. Thinking of using the Atmos production suite to make them but there’s no way of listening back to check it. Sent from my iPhone using Tapatalk
Richard Spooner Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM. www.spoonsound.com |
Your settings are very similar to the default setup in a Dolby Digital encoder so should be an acceptable starting point but the only way to know you have it right for your mix is to constantly check, check, check. It's a double compromise too as you first have to compromise your 5.1 mix to a Matrixed Lt/Rt stream & check the decoded version in 5.1 (and this is hard enough) but you also have to compromise your stereo - and for me this was always the biggest problem as it is a serious compromise and a dedicated stereo mix will always sound better (at least to my ears it does). I can highly recommend the RPGA Surround document as a good start point.
I was about to write more or less exactly the same thing.
MacPro 5.1 (2 x 3.46 GHz, Twelve Core Intel Xeon) - OS X 10.14.6 - Ram 64G - PT Ultimate 2022.10.0 - HD Native Card - Avid HD Omni - Monitoring PSI Audio (surround) |
The last 2 films I did they only asked for stereo so I gave them LoRo because it sounds better. So if you're seeing the same thing we can only hope it will spread out elsewhere? LoRo usually sounds pretty good decoded to 5.1 anyway.
A LoRo will only upmix into faux surround - it will not decode because there is nothing to decode.
Question about 5.1 downmix from ATMOS | critictalk | Post - Surround - Video | 0 | 07-06-2019 03:15 AM |
Downmix to mono | dunebuggy | Pro Tools HDX & HD Native Systems (Mac) | 6 | 08-29-2012 12:42 PM |
Does this mono downmix box exist? | bdangler | Post - Surround - Video | 19 | 07-11-2010 09:10 AM |
How to Downmix 5.1 to Stereo via aux/busses | vudoo | Post - Surround - Video | 5 | 03-25-2009 07:43 PM |
downmix problem | minister | Post - Surround - Video | 11 | 01-21-2005 06:24 AM |
