Import audio command doesn't work
the import audio command doesn't work, so the workaround is drag and drop the file, Avid gives a solution now or when
a what do you knows thanks from now
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
Re: Import audio command doesn't work
How is it not working?
Ben Rubin Producer//Mixer//Bassist//Composer benrubin.com ------------ PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive, Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1 |
Sorry forgot to say
Am in Capitan And PT 11.3.1 I saw in DUC Import audio command not working,need frugal an drug and drop the dile to edit window
There's your problem right there - PT11 and ElCapitan. Not tested or supported by Avid so you're on your own here if you expect help from Avid. So you can expect strange issues.
If you run Pro Tools on a Mac don't be in a hurry to use the latest OSX. It can take months for Pro Tools and plug ins to be debugged.
For PT 11 I would say the best place to be would be 10.8.5 ML
Agreed. OSX 10.9.5 ain't too shabby either.
Does "Automatically Copy Files on Import" work with Import Audio command? | leftalive | Pro Tools 10 | 3 | 04-17-2013 09:35 PM |
Import Audio function doesn't work in 8.03 | resway | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 21 | 04-02-2010 09:03 PM |
Drag audio files after import doesn't work!!! | tj_davies | Pro Tools TDM Systems (Mac) | 4 | 12-09-2009 02:47 AM |
Just installed 6.7 and now Command 8 doesn't work? | cc1 | Pro Tools TDM Systems (Mac) | 4 | 11-01-2004 03:10 PM |
why doesn't "import audio to track" work now? | Dayliner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-26-2004 05:17 PM |
