Old 04-29-2020, 12:37 AM
LukeHoward LukeHoward is offline
Default Avid HDX CoreAudio on Catalina
Does this work? With Ableton, selecting the HDX CoreAudio driver (obviously Pro Tools is quit) is very unreliable. Mostly it doesn't work and the MTRX briefly loses its connection with DADman. On the latest everything (2020.3 Pro Tools and HD driver).
https://lukehoward.com/
Old 04-29-2020, 01:15 AM
LDS LDS is offline
Default Re: Avid HDX CoreAudio on Catalina
That has been my experience with HDX and Ableton Live for quite a while now - possibly late 2018 onwards. I've just gotten used to sending my Omni audio via my system audio outputs when using Ableton. It seems to be specific to Ableton and HDX, as CoreAudio is working pretty well here for other applications. Much better than the 2019.12 HD driver which would jam up and do weird things when trying to change settings in audio midi setup.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 04-29-2020, 01:31 AM
Interesting! Well, I went back to ReWire'ing into Pro Tools – which I haven't used for years – and it seems to work pretty nicely. Just makes Ableton a bit less useful as a composing tool as you can't use third-party plugins, M4L, etc. (I also tried using Dante, either straight into the MTRX or via Pro Tools, but the latency is pretty bad. I don't really want to have to buy another audio interface just to use Ableton!)
Old 04-29-2020, 08:45 AM
lucienpalmer lucienpalmer is offline
Do you have dante on you MTRX? You could install dante virtual sound card and have any software like ableton send directly to DADman. It even gives you separate volume controls. And additional options to reroute the signal back into PT to record, etc.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 04-29-2020, 10:07 AM
See above 😉
Old 04-29-2020, 03:25 PM
Originally Posted by LukeHoward View Post
See above
Meh, I suck. Read your post too fast.
Old 04-29-2020, 03:29 PM
JFreak's Avatar
JFreak JFreak is offline
Post of the day
Janne
Old 04-29-2020, 08:39 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Latency is the Dante unknown to most iMo
Not receiving a MTRX-Studio preorder yet...
1. Did you get the code for Dante' or pay extra?
Old 04-29-2020, 09:30 PM
Not sure if I'm understanding right but – I have a MTRX, the Dante option is just that (an option, a physical card that you need to install in the unit). I believe Dante is included with the MTRX Studio as a no-cost option, but best to check with Avid if you are unsure.
The latency I spoke of in my earlier post is due to using Dante Virtual Soundcard (DVS), which has a minimum Dante latency setting of 1ms, which increases once you include the application's buffer sizes. This latency would be obviated using a hardware solution such as a PCIe Dante card but, at that point there are other options (e.g. just a standard USB or Thunderbolt interface with AES/EBU or MADI outputs).
Old 05-07-2020, 08:07 PM
Bill_Kelley Bill_Kelley is offline
Thanks, Luke. At least now, I know the problem is with Ableton, not avid. I hope to see some results from your ticket with Ableton. In the meantime, I will try out the rewire option. Hopefully I will be able to record audio into Ableton this way.
Music, it's a mystery...
Avid Pro Compressor/Limiter & Catalina Becharax General Discussion 7 02-14-2020 12:00 PM
macOS 10.15 (Catalina) and Avid Products Avid Technical Alerts 0 10-07-2019 11:11 AM
Only 8 Outs/Ins Avid CoreAudio Manager max0623 Pro Tools HDX & HD Native Systems (Mac) 3 05-10-2016 04:55 AM
Avid CoreAudio Manager with 2 HDX Cards? BillDog793 Pro Tools HDX & HD Native Systems (Mac) 0 05-28-2014 07:11 PM
Avid coreaudio problem efisch Pro Tools 11 2 01-08-2014 05:27 PM
