Old 05-06-2011, 08:10 AM
SBMusicAndPost SBMusicAndPost is offline
Default Loss of Control
Anyone seen this yet?
10.6.6 PT HD 8.1 and 8.0.5
Recording or playing back in new or pre existing sessions and upon hitting STOP an assertion error occurs. After clicking OK the transport continues to roll. You can not Command . or stop using the keyboard or software transport controls. Zoom functions and mouse till work but no transport control works. Only option is to force quit or close the session and restart.
Creating a new user account seems to make the problem go away but Im looking for an explanation or solution. This is happening on two different machines... thinking about a clean install of the OS and reinstalling EVERYTHING.
Steve
Hyperbolic Audio, NYC
Old 05-06-2011, 10:25 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Loss of Control
Steve
Happening on 2 machines is strange! As i suspect its most likely caused by an out of date plugin or possibly a connected hard drive with issues? have you got any firewire or USB drives connected? maybe try un-mounting them and see if it still happens. but an out of date or incompatible plugin is the most likely cause. so go through your plugin and check them all. they don't have to be in the session? just in the plugins folder to cause issues.
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-06-2011, 10:58 PM
loopzilla2 loopzilla2 is offline
Same thing here.
Control 24 loss of Faders "possible power supply problem"? Kevin101 ICON & C|24 3 07-15-2020 03:10 PM
Sad about loss of Pro Control in PT11 Ru_C Pro Tools 11 37 04-17-2013 03:18 PM
MC Control & PT 9.0.2 Connectivity Loss boomspot Artist Series 0 05-31-2011 07:01 PM
Freezes - Turns white - Loss of control 7.1 LE Mbox 1 *DELETED* Andy Gerome 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-12-2008 01:10 PM
Loss of Midi Pre Control roberts Pro Tools TDM Systems (Mac) 0 04-05-2008 02:32 PM
