Old 08-20-2008, 11:43 AM
felix822 felix822 is offline
Default Low latency in Pro Tools 7.4
How do I turn off low latency in Pro Tools 7.4?
Old 08-20-2008, 11:55 AM
JMS40 JMS40 is offline
Default
Options > Low Latency Monitoring
Old 08-20-2008, 11:58 AM
Default
Thanks, not sure how I missed that.
Old 08-20-2008, 04:29 PM
Default
Mine doesn't have that option.
Old 08-20-2008, 04:38 PM
SeedGuy SeedGuy is offline
Default
What hardware you running?
Old 08-20-2008, 04:40 PM
Default
MBox2, thanks.
Old 08-20-2008, 04:56 PM
DigiTechSupt's Avatar
Default
Originally Posted by felix822 View Post
MBox2, thanks.
Mbox 2 won't have that option as it has hardware monitoring. Only devices without hardware monitoring have the low latency monitoring option (002/003 series).
Avid Audio Tech Support
Support FAQ
Old 08-20-2008, 04:57 PM
Default
But I thought Pro Tools itself has that option. Am I wrong?
Old 08-20-2008, 05:35 PM
The Weed's Avatar
The Weed The Weed is online now
Default
Pro Tools has the option, depending on the hardware, as stated above by the Digidesign representative who has been kind enough recently to be on the forums on a semi-regular basis, which we all appreciate.
Since you have an MBox2, not the Pro, you have the MIX KNOB to provide zero-latency analog monitoring, ie HARDWARE MONITORING, again, as stated above. Use the Mix Knob to blend and adjust the ratio between the MBox2's analog input and Pro Tools LE's playback. For more information, refer to your Getting Started Guide. You did read that, yes?
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-20-2008, 05:46 PM
Default
Cheers,
Ok I understand now. Thanks for the help everyone. And yes I did read it
Pro tools SE Latency AnnoyedSE Pro Tools SE and Essential (Win) 6 03-13-2013 05:41 AM
How Can I Get Rid Of Latency In Pro Tools Le? R.O. Post - Surround - Video 3 12-05-2011 03:17 PM
Pro Tools 9 Latency... akhafaji Pro Tools 9 10 02-01-2011 02:48 PM
Pro tools latency obsuleet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-11-2007 12:04 PM
Pro tools Latency! NBASE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-02-2007 04:55 PM
