crackle w/volume control
I have a command 8 that I use with a digi 002 rack. I send my audio L/R out thru the "main out" of the rack, and into the main L/R of the command 8, and then out to the monitors. I do this because it's easier to use the volume control on the command 8 than for me to reach all of the way to the 002 rack to adjust with the "monitor level" dial.
my problem is that when I adjust the volume knob on the command 8, there is a slight crackle sound out of my left speaker, but only when the knob is moving. There are no audio problems besides, this -- I still get a clean signal -- it just gets lets out a scratchy sound when i deflect the knob. I troubleshooted the problem (it's not the cable; i also switched the left and right outputs, and the same thing happened in the right speaker.) It's clearly something related to the command 8. Does anyone know what it could be? |
Re: crackle w/volume control
A defective pot, it's one of the flaws in that particular production run. I have the same thing, and a friend of mine too. He sent the C|8 in for repair (it was still under warranty) and it came back with a new pot and has never had that issue anymore...
Mine is out of warranty...I'm tempted to open it up and replace the volume pot myself...I guess it's not too big of a deal...it must be a few soldering points and that's it...you just have to find a pot with the same exact specs as the original. Hope this helps L.G. |
Mbox 3 USB Makes Strange Crackle noise from the left output when adjusting the volume | NatiTaub | FireWire & USB Audio Interfaces (Mac) | 0 | 04-06-2013 08:57 AM |
DB-33 Volume control | siscok5lyt | Windows | 5 | 03-06-2013 01:53 PM |
Volume control | ice0-5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-29-2010 02:59 PM |
VCA volume control | DustinWhitt | Pro Tools TDM Systems (Mac) | 2 | 09-07-2006 09:48 AM |
Volume Control of an IAC bus | stevemusic | MIDI | 1 | 12-11-2003 06:25 PM |
