  #101
Old 02-25-2020, 11:54 PM
Oblivion777's Avatar
Oblivion777 Oblivion777 is offline
Default Re: New Mac Pro (7.1)
I'd go for 1GB. Definitely. I don't know if a separate drive is still recommended, but what I've done in my MacPro 2019 is that I've put in a OWC 4TB drive and have allocated 3GB for libraries (RAID) and 1GB for audio. It's the same drive, but AFAIK these drives actually contain 4x 1GB SSD's. The PCIe slot is more than capable of handling the data for the libraries and for audio. I ran a BlackMagic read/write test and on the 3GB I reach speeds of more than 5GB read/write and on the 1GB audio more than 2.5GB read/write.
Main DAW: MacPRO 7.1, 16-Core Xeon 3.2GHz, 196 GB RAM, OSX 10.15.2, HDX3, PT 2019.12 Ultimate, 2x UAD-2 PCIe Octo's, Raven MTZ, 1x HD Omni, 2x HD I/O's, 1x MTRX and some more cool stuff...
Auxilary DAW: MacBook Pro with Retina Display (2012), 2.6GHz quad-core Intel Core i7, 16GB RAM, OSX 10.13.6, PT2019 Ultimate, 1x UAD Apollo Quad Audio Interface /w Thunderbolt Interface (v9.x)
  #102
Old 02-25-2020, 11:59 PM
JFreak's Avatar
JFreak JFreak is offline
I would keep it in one APFS container to get full speed for everything. As you may or may not know, with APFS if you have 4TB physical storage you do not need to limit yourself to hard-partition it to 3+1TB but instead can create 4+4TB "volumes" that share the physical capacity of the "container". As long as the total used space fits into container all is well.
Janne
  #103
Old 02-26-2020, 12:14 AM
What exact OWC 4TB card? This one: https://eshop.macsales.com/item/OWC/SSDACL4M204T?
The issue with that card is it's stuffing four PCIe 3 x 4 lane M.2 cards into 8 total PCIe 3 lanes. So half the raw PCIe bandwidth on paper, although you'll see a lot less than that decrease for typical use. And all this is so much faster than what most folks are used to it may not be worth worrying about.
OTOH if you really want to build the fastest possible SSD storage with four M.2 drives you need a x16 lane card. Like this one https://www.sonnettech.com/product/m...pcie-card.html. And my personal bias would be to go with Samsung M.2 SSDs. Including if you really want to squeeze most write performance and wear life then the the 970 Pro, but for most folks the 970 Evo is fine (and cheaper per GB and available in larger sizes).
These computers are great... but the new crop of PCIe 4 M.2 cards are arriving and they are fast, I've been lucky enough to play with them on some AMD servers. And the PCIe 6 standard is being worked on for 2021... isn't the technology treadmill wonderful
  #104
Old 02-26-2020, 12:16 AM
LukeHoward LukeHoward is offline
Which is very cool! Clearly they got that idea from ZFS :)
You still need to use RAID to aggregate the 4x1TB drives into a disk upon which you can create the APFS container, as I understand it – the card is just a ”dumb” PCI switch from the NVMe SSDs to the PCI bus. (BTW does anyone know if the MacPro7,1 supports PCIe bifurcation?)
https://lukehoward.com/
  #105
Old 02-26-2020, 12:18 AM
Originally Posted by Darryl Ramm View Post
... but for most folks the 970 Evo is fine (and cheaper per GB and available in larger sizes).
Or 970 Evo Plus.
  #106
Old 02-26-2020, 12:22 AM
Originally Posted by LukeHoward View Post
Or 970 Evo Plus.
Yes, but the Evo Plus really does not give any benefit over the Evo and folks were scared off after previous problems (which were fixed) with those drives. So I generally just don't mention them.
  #107
Old 02-26-2020, 03:05 AM
This one:
OWC Accelsior 4M2
https://eshop.macsales.com/shop/ssd/owc-accelsior-4m2
  #108
Old 02-26-2020, 04:54 PM
OK great, will be stonking fast compared to SATA etc. but to restate my earlier point that is a x8 card so if you have a x16 slot in your new Mac free you are giving up some performance.
  #109
Old 02-27-2020, 04:16 AM
nojubilees nojubilees is offline
Hi all. I'm just looking at aux cables for our Mac Pro 7,1 with the AVID HDX cards. Is it absolutely necessary to go with the Belkin kit, or could we just get a standard 6pin mini to 6pin PCIe aux cable like this one https://www.moddiy.com/products/Appl...wer-Cable.html
Cheers all.
  #110
Old 02-27-2020, 11:49 AM
uptheoctave uptheoctave is offline
Cheers all.
That looks like it will work but there is no official guidance from Avid or Apple on how to get this working.
Either try it and see (and let us know) but at your own risk, or wait until Avid come up with a recommended configuration.
I think I was one of the first people to get HDX working- mine is still going strong but not everyone has been so lucky.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
