Eleven Rack & Ground Control Pro MIDI Problem: Amp Output keeps turning off!
I recently bought a ground control pro that has had no problems what so ever and is working great. I've used it with the Avid Eleven Rack with no problems and it is a great unit. My problem is that now for no reason at all the Amp Output of each rig in Eleven Rack (CC# 92) is randomly turned all the way off to -60.0dB for no reason. If you've seen a Ground Control Pro before you know there are 4 Preset select buttons closest to your feet and to the edge of the unit. When I select a preset from the left -> (Ex. Select Preset 1 then Preset 2), Preset 2 suddenly has an Amp Output of -60.0dB. I did NOT tell any MIDI command to do this and I don't really know how I would so I definitely didn't do anything to it. BUT! When I select a preset from the right <- (Ex Select Preset 3 then Preset 2) the output is fine. But to contradict this even more, if i continue from the right and select preset 1, THAT Amp's Output is now at -60.0dB too! This is ridiculous and the only thing I think that could be causing this is a faulty MIDI cable but I would like to know if anyone else has run into any similar issues with randomly sent MIDI CC messages and if they were able to fix these easily. Thank you all so much. |
Re: Eleven Rack & Ground Control Pro MIDI Problem: Amp Output keeps turning off!
I'd hazard a guess that the problem is more likely one of programming than it is a faulty cable.
Either way, your hypothesis is easily tested by substituting another MIDI cable. |
I would say it's programming but It's just that the volume doesn't turn off all the time, therefore I don't think it's being programmed to do that because it would send the same message everytime. I just thought there might possibly be a real quick answer that someone might know but if not I'll just try a new cable.
My Ground Control lights aren't syncing to my Eleven Rack | Dr Git | Eleven Rack | 6 | 05-30-2013 01:45 PM |
Eleven Rack & Ground Control Pro Template | guitarorth | Eleven Rack | 2 | 03-10-2012 01:33 PM |
Voodoo Ground Control and Eleven Rack Setup Please Help! | HipHopWong | Eleven Rack | 7 | 11-11-2011 12:45 PM |
Eleven Rack Control Panel Problem | MichaelUR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-01-2011 12:13 AM |
Eleven Rack Ground Control Pro Axiom 25 | Scott Paige | Eleven Rack | 1 | 10-19-2010 02:15 AM |
