Old 05-06-2009, 10:33 AM
moonfish1 moonfish1 is offline
Default pro tools 7.3 won't launch
I tried to install a plug-in which didn't work (I think) and know I can't launch pro tools..It says: Required software extensions are missing. Click on the OK button and you will be transferred to the PACE website where an installer can be downloaded".
This website says that MAC OS 10.5 might not be enough to solve the problem, and it doesn't solve the problem so WHAT SHOULD I DO!??
I hate computers and I'm such an idiot..
Anyone a clue?
Thanx
Marcel Hulst (Amsterdam)
Old 05-06-2009, 10:34 AM
Default Re: pro tools 7.3 won't launch
Anyone a clue?
Thanx
Old 05-06-2009, 10:41 AM
crizdee's Avatar
crizdee crizdee is offline
Anyone a clue?
Thanx
You should either download and install the pace software so you have the latest pace interlock drivers installed needed for the plugin you installed or remove the plugin from the plugins folder system drive/library/app support/digidesign/plugins. then try booting up PT
Chris
Producer, Engineer,
www.ukmastering.com
Old 05-06-2009, 02:04 PM
mix109 mix109 is offline
Or perhaps whatever plug-in you installed downgraded(?)your current pace/interlock drivers,so PT wont launch....
Any way you should follow Chris suggestion,and then see if the plug needs to be removed
You probably use MacOSX 10.4...
http://www.paceap.com/extensions/macextsx.dmg
Pro Tools 10.3.5 Won't Launch :-( Grinch Pro Tools 10 4 05-09-2013 02:50 PM
Pro tools 8.04cs2 upgrade, Pro tools wont launch! Please help me! ohyoshimi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-19-2011 11:15 PM
I cant Launch my Pro Tools Le 8.0.3 Duceman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-24-2010 08:45 PM
Pro Tools won't launch - 'Pro Tools LE quit unexpectedly' joey141 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-11-2009 03:18 PM
Pro Tools won't launch... PaulG1522 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-19-2009 04:07 PM
