HW buffer size 64 samples..?..
Dear Forum.
I always do projects in 24/48. In some projects I set HW buffer as low as 64 samples. In others, the settings only goes as low as 128 samples. I need the lowest possible settings recording triggered drums... What can I do to get the lowest possible setting? __________________________________________________ _______________ MacPro 3.1 ProTools 9.0.5 TDM3 2x192 I/O |
Re: HW buffer size 64 samples..?..
It depends on how you set the number of voices.
On my sys I can lower the buffer down to 64 with 96 voices/2dsp, and 48 voices/1dsp. If you allocate more dsp per voices you can't go down to 64 samples.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
Thanks. I´ll try that. I guess it will do the thang.
32 Samples H/W Buffer Size playback with 192 I/O | MikeLip | Pro Tools HDX & HD Native Systems (Win) | 16 | 09-10-2011 12:36 PM |
can't change h/w buffer size above 128 samples | mmiller | Pro Tools M-Powered (Win) | 6 | 07-24-2010 10:42 AM |
I Want H/W Buffer Size of 2048 samples on 002R | jbaby | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-05-2008 03:44 PM |
HELP....H/W Buffer Size @ 128 Samples or less DOENS'T WORK AT ALL | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 12-31-2002 05:17 PM |
My whole system crash when i set my H/W Buffer Size @ 128 Samples or less | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-29-2002 02:50 AM |
