Old 06-14-2020, 07:18 AM
Richard901 Richard901 is offline
Default Mac - Spotlight cannot find ptx files when they are resaved
I use Smart Folders (saved searches) in macOS to easily find and load Pro Tools sessions.
This has worked well, but I recently found a problem:
1. Create a new Pro Tools session - the new ptx session file automatically appears in the saved search folder.
2. Resave the session with File/Save - the ptx session file in the saved search folder disappears.
3. File/Save As and overwrite the session with the same name - the ptx session file in the saved search folder reappears.
The same things happens when I directly search for the ptx file with Spotlight.
Spotlight cannot find the ptx file when it is resaved with File/Save.
I didn't used Pro Tools for a few months, so I’m not sure whether a certain PT update or macOS update caused this problem.
I haven't found another application that shows this problem.
Can anyone confirm the problem?
Thanks for your help.
A Guide to Using Smart Folders on MacOS
https://theproductiveengineer.net/a-...ders-on-macos/
Pro Tools 2023.9
Ventura 13.6
Old 06-14-2020, 06:10 PM
Ben Jenssen's Avatar
Default Re: Mac - Spotlight cannot find ptx files when they are resaved
I'm definitely no expert, but I have used a bit of smart folders and folder scripts over the years. Could it be a finder/spotlight problem? That mds process not updating? A simple save in PT is in essence replacing the session file with a new session file.
Does it show up after a while, after a restart? A restart of the Finder, perhaps?
Might there be a way to "force" a update of the mac "file awareness"?
Old 06-15-2020, 02:32 AM
Ben - Thanks for your helpful suggestions.
It doesn't show up after Mac or Finder restarts.
Some new things I've tried.
1. Close and restart Pro Tools and then open the file from the Open/Recent menu - It does not reappear.
2. Close and restart Pro Tools and then open the file by double clicking on the real ptx file in the PT Sessions folder - It reappears.
Might there be a way to "force" an update of the mac "file awareness"?
3. Reindex Spotlight by adding and then deleting my drive in System Preferences/Spotlight/Privacy - It reappears, but disappears again when resaved.
It looks like it's a Spotlight problem on my computer. Strange it only affects Pro Tools.
I've got a spare SSD, so I'll try doing a fresh test installation of Mojave to see if there's still a problem.
Pro Tools 2023.9
Ventura 13.6
Old 06-15-2020, 07:39 AM
I've tried this:
Different SSD - reformatted.
Fresh installation of Catalina 10.15.5 - I was using Mojave.
Only system SSD attached.
No other third party software installed.
Pro Tools 2020.3
New session.
Same problem - the session ptx file in the Saved Search folder disappears when the project is resaved.
Pro Tools 2023.9
Ventura 13.6
Missing fade files, missing audio in resaved sesssions drygruo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-14-2010 04:56 PM
Spotlight can find PT Documentation, but PT itself can't? The Dubnicks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-16-2009 04:53 AM
Spotlight and Find command disabled by Protools? Zownd Pro Tools TDM Systems (Mac) 2 06-05-2008 07:59 AM
Spotlight and "Find" suddenly not working? JKD99 Pro Tools TDM Systems (Mac) 2 02-11-2006 12:48 PM
*HELP* LE 6.2 can't find any of my files! Brandon Burke 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-29-2004 11:35 AM
