Playlist Selection Behavior - Linear vs Cycle
I'm on 12.8.2, previously 12.7.x.
Cycling through playlists used to be linear - you could scroll through the playlists and at the end of the list you could go no further. Somewhere in 12.6 or 12.6 that behavior changed and playlist selection became a cycle - meaning you could scroll through with key commands or a surface and when you reached the last playlist you could keep going and go right back to the first playlist. At first, I hated this - but I got used to it and found that it sped up comping. With 12.8.2, this behavior is back to the traditional behavior. Is there a way to restore the cycling behavior? I looked through prefs and couldn't find it. Best...H |
Re: Playlist Selection Behavior - Linear vs Cycle
I ended up seeing the value in the alternate (cycling) behavior - wish they had made it a preference.
Thanks for your help. Best...H |
Copy Selection to Main Playlist bug - can you check if PT 12 has it too? | jacko | Pro Tools 12 | 1 | 07-27-2015 11:40 PM |
Vertical Jumping With Edit Selection In Playlist View | soundlabyrinth | macOS | 11 | 09-24-2012 06:37 PM |
Retaining Selection in PlayList Editing | sydphi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-09-2003 08:21 PM |
playlist selection by group? | Ray Lyon | Tips & Tricks | 1 | 02-02-2001 11:15 PM |
