HD Native 12.5.2 CPU Spikes
Hello all! I built a new Pro Tools PC running Windows 10 Pro a short time ago, and usually I'm able to go through the hardware recommendations threads and such and come up with a good stable system. This time, though, for whatever reason I'm going nuts trying to figure out what I've done wrong. I've done the Windows optimizations Avid recommends. I'm running a PCIe HD Native card.
The issue is, I'm getting severe CPU spikes. I created an 88.1kHz/24bit session with 24 audio tracks (only two of which have any audio on them yet) and can't play through an entire 3:30 song without getting error messages that Pro Tools is running out of CPU. I have tried removing plugs from the plug-ins folder thinking maybe I had a bad plug-in but that didn't resolve anything. I haven't tried removing EVERYTHING, but I pulled out everything that wasn't a stock Avid plug. I'm running a click in the session but removing it didn't help anything. Otherwise I have NO plug-ins in the session. I am using aux outs to send audio out to my mixer, but no plug-ins. Anyway, if anyone has any suggestions I'd greatly appreciate it. As it stands my system is completely unusable. If I haven't provided enough information or if this is the sort of thing I should be pursuing through more official channels, please let me know. Thanks very much for any help! edited to add: I started out on 12.5, and updated to HD Native 12.5.2 hoping the update would fix this issue, but it remains. I have not tried installing any versions of Pro Tools older than 12.5 on this system. Should I? Sandra report: SiSoftware Sandra ID Host Name : DAW2016 Workgroup : WORKGROUP Computer Model : GigaByte Serial Number : To be fille*********** Chassis : Desktop Mainboard : GigaByte X99P-SLI-CF Serial Number : To be fille*********** BIOS : AMI (OEM) F2 11/12/2015 Intel vPro : 9.01.10.1005 Total Memory : 63.84GB DIMM DDR3 DDR4 Processors Processor : Intel(R) Core(TM) i7-5930K CPU @ 3.50GHz (6C 12T 3.5GHz, 3.5GHz IMC, 6x 256kB L2, 15MB L3) Socket/Slot : FC LGA2011 Chipset Memory Controller : Gigabyte Xeon (Haswell-E) DMI2 100MHz Memory Controller : Intel Xeon (Haswell-E) Integrated Memory Controller 0 Target Address, Thermal & RAS Registers 100MHz, 4x 16GB DIMM DDR3 DDR4 2.13GHz 256-bit Memory Controller : Intel Xeon (Haswell-E) Integrated Memory Controller 1 Target Address, Thermal & RAS Registers 100MHz Memory Module(s) Memory Module : G.Skill F4-2400C15-8GRK 8GB DDR4 PC4-19200U DDR4-2400 (15-15-15-36 4-51-16-5) Memory Module : G.Skill F4-2400C15-8GRK 8GB DDR4 PC4-19200U DDR4-2400 (15-15-15-36 4-51-16-5) Memory Module : G.Skill F4-2400C15-8GRK 8GB DDR4 PC4-19200U DDR4-2400 (15-15-15-36 4-51-16-5) Memory Module : G.Skill F4-2400C15-8GRK 8GB DDR4 PC4-19200U DDR4-2400 (15-15-15-36 4-51-16-5) Memory Module : G.Skill F4-2400C15-8GRK 8GB DDR4 PC4-19200U DDR4-2400 (15-15-15-36 4-51-16-5) Memory Module : G.Skill F4-2400C15-8GRK 8GB DDR4 PC4-19200U DDR4-2400 (15-15-15-36 4-51-16-5) Memory Module : G.Skill F4-2400C15-8GRK 8GB DDR4 PC4-19200U DDR4-2400 (15-15-15-36 4-51-16-5) Memory Module : G.Skill F4-2400C15-8GRK 8GB DDR4 PC4-19200U DDR4-2400 (15-15-15-36 4-51-16-5) Video System Monitor/Panel : ACR G257HU (2560x1440, 24.9") Video Adapter : NVIDIA GeForce GT 730 (2CU 384SP SM5.0 901MHz, 512kB L2, 2GB 1.8GHz 64-bit, PCIe 2.00 x8) Graphics Processor CUDA GP Processor : NVIDIA GeForce GT 730 (384SP 2C 901MHz, 512kB L2, 2GB 1.8GHz 64-bit) OpenCL GP Processor : NVIDIA GeForce GT 730 (384SP 2C 901MHz, 32kB L2, 2GB 1.8GHz 64-bit) Compute Shader Processor : NVIDIA GeForce GT 730 (384SP 2C 901MHz, 512kB L2, 2GB 1.8GHz 64-bit) OpenGL Processor : GeForce GT 730/PCIe/SSE2 (2GB) Storage Devices Samsung SSD 850 PRO 512GB (512.1GB, SATA600, SSD, SED) : 477GB (D:) Samsung SSD 850 PRO 512GB (512.1GB, SATA600, SSD, SED) : 477GB (F:) NVMe Samsung SSD 950 (512.1GB, PCIe) : 477GB (C:) WDC WD40EFRX-68WT0N0 (4TB, USB/SATA600, 3.5", 5400rpm) : 4TB WDC WD1002FAEX-00Y9A0 (1TB, USB/SATA600, 3.5", 7200rpm) : 932GB WDC WD6402AAEX-00Z3A0 (640.1GB, USB/SATA600, 3.5", 7200rpm) : 596GB WDC WD1002FAEX-00Z3A0 (1TB, USB/SATA600, 3.5", 7200rpm) : 932GB WDC WD40EFRX-68WT0N0 (4TB, USB/SATA600, 3.5", 5400rpm) : 4TB Msft Storage Space (5TB, Virtual) : 5TB (G:) TSSTcorp CDDVDW SH-224GB (SATA150, DVD+-RW, CD-RW) : N/A (E:) Logical Storage Devices Sessions (D:) : 477GB (NTFS, 4kB) @ Samsung SSD 850 PRO 512GB (512.1GB, SATA600, SSD, SED) Samples (F:) : 477GB (NTFS, 4kB) @ Samsung SSD 850 PRO 512GB (512.1GB, SATA600, SSD, SED) System Reserved : 350MB (NTFS, 4kB) @ NVMe Samsung SSD 950 (512.1GB, PCIe) ExternalStorage (G:) : 5TB (ReFS, 64kB) @ Msft Storage Space (5TB, Virtual) Hard Disk (C:) : 476GB (NTFS, 4kB) @ NVMe Samsung SSD 950 (512.1GB, PCIe) Hard Disk : 450MB (NTFS, 4kB) @ NVMe Samsung SSD 950 (512.1GB, PCIe) Optical Drive (E:) : N/A @ TSSTcorp CDDVDW SH-224GB (SATA150, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : Gigabyte Wellsburg LPC Controller LPC Legacy Controller 1 : T2 86-20 Audio Device : Gigabyte Wellsburg HD Audio Controller Audio Device : AVID Tech HD Native Disk Controller : Gigabyte Wellsburg sSATA Controller [AHCI mode] Disk Controller : Gigabyte Wellsburg 6-Port SATA Controller [AHCI mode] Disk Controller : Samsung NVMe SSD Controller USB Controller 1 : Gigabyte Wellsburg USB xHCI Host Controller USB Controller 2 : Gigabyte Wellsburg USB Enhanced Host Controller #2 USB Controller 3 : Gigabyte Wellsburg USB Enhanced Host Controller #1 USB Controller 4 : 8738 DSL6540 USB 3.1 Controller [Alpine Ridge] SMBus/i2c Controller 1 : Intel ICH SMBus SMBus/i2c Controller 2 : Intel SNB/IVB/HSW-E XMB Ch 0 SMBus SMBus/i2c Controller 3 : Intel SNB/IVB/HSW-E XMB Ch 1 SMBus Printers and Faxes Printer : Microsoft XPS Document Writer v4 (600x600, Colour) Printer : Microsoft Print To PDF (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Brother Generic Jpeg Type1 Class Driver (600x600, Colour) Scanners and Cameras Scanner : Microsoft Brother MFC-J6920DW [30055c9e70ad] (Scanner, USB) Network Services Network Adapter : Intel(R) Ethernet Connection (2) I218-V (Ethernet, 1Gbps) Power Management Battery No 1 : CPS CP1500PFCLCD Operating System Windows System : Microsoft Windows 10 Professional 10.00.10586 Platform Compliance : x64
Joshua L. Decatur, AL |
Re: HD Native 12.5.2 CPU Spikes
12.4 might be worth a try. 12.5.x seems to spike CPU more for me too.
Greg
Intel i7 3930K, Gigabyte GA-X79-UP4 (rev 1.0), 32 GB Corsair Vengeance 1600 ram, EVGA Nvidea GT 720 TI video card, a Samsung 850 Pro (256 GB) OS drive, 2 Samsung 850 Pro's (512 GB) in externally mounted drive bays for session and sample storage, Win 10 Pro, PT Ultimate (Native)2019.10, HD Omni, HD I/O 16x16 . |
I know this is not a Mac but I saw this yesterday about the Haswell CPU's
http://avid.force.com/pkb/articles/t...OS-X-Mavericks Down toward the bottom, it mentions Haswell issues with Avid and 3rd party setups
Seeing similar here. I may be going back to 12.4 myself.....
12.4 has been reasonably solid here.
I am getting a lot of work done on 12.5, but I am also seeing many -9173 errors. Commiting and/or freezing VI's and the click seem to make it better, but still not great. So far, none have caused a crash(I just hit Ok and continue on with my editing). Its only stalled on me once during a record pass. I have a full band tomorrow so that may be "interesting"(or may force me to reboot to my old system drive with 11.3 on it)
Does HD native or native native disable plugins when monitoring inputs? | BasketCase | Pro Tools HDX & HD Native Systems (Mac) | 7 | 05-20-2013 08:48 AM |
CPU spikes with PT8 | PTLExp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-04-2009 04:54 PM |
SSL4000 native/ Renmaxx native/ DUY everpack native!!! | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-22-2007 07:58 AM |
TL Space Native: CPU spikes and audio glitches | UK RAF | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-12-2007 01:15 PM |
If your having spikes..... | req06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-15-2006 11:25 AM |
