Old 10-25-2013, 05:04 PM
benderissimo benderissimo is offline
Default Artist Mix Layouts saved when surface not connected?
I have two artist mix controllers that I with a laptop based Pro Tools 10 system. I do most of my work with the surfaces attached but I'll often need to tweak sessions on my laptop when I'm in another location. I've just built a session template that contains a number of layouts and was wondering if I'll lose those layouts if I start a project with the Artist Mixes attached but then make changes when they're not attached and save the session. Can anyone confirm this?
Old 10-25-2013, 08:39 PM
Default Re: Artist Mix Layouts saved when surface not connected?
OK, just tested it and it appears to still save that data even when the session is opened and saved without the control surface connected. Phew!
A tip on a quick way to do you own layouts on Artist Control Audioartist Artist Series 5 02-05-2015 03:17 AM
chosing layouts with artist transport? b.riesel Artist Series 4 01-27-2014 09:10 AM
Avid Artist Mix Eucon - Switching between Layouts silentmoon Artist Series 2 03-09-2013 07:42 AM
Ideascale for layouts to be saved in ptx file Brent_Sydney Artist Series 10 10-04-2012 09:25 AM
Storing Layouts on Artist Mix?? tomhartman Artist Series 16 07-13-2012 04:15 AM
