Old 08-30-2010, 09:34 AM
DougHarrison DougHarrison is offline
Default Mac External Keyboard and Mouse not working
I recently obtained an entry level position in a pose house and bought a 20" AOC Monitor and a usb mac keyboard to accommodate my 12" macbook pro to help the flow of work on pro tools LE 8.0.4. Everything works fine until i start up pro tools. One of two things happens, either the mouse and keyboard completely freeze and stop working, or just the keyboard stops working. but as soon as pro tools closes, everything is fine. This has become extremely frustrating to me because a search on google for this issue of course brings thousands of pages of instrumental keyboard issues.
Any help would be much appreciated, thanks.
Old 08-30-2010, 11:39 AM
Default Re: Mac External Keyboard and Mouse not working
What interface are you using? Maybe you need to change some USB ports? Disconnect the PT interface and see if you can get the mouse/keyboard to work first, then add the interface.
Old 08-30-2010, 01:27 PM
Park Seward's Avatar
Park Seward Park Seward is offline
Describe how the keyboard, mouse, external drive and PT are hooked up.
What OS?
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 08-30-2010, 02:42 PM
My Mac Book Pro is Running 10.6.4
My USB keyboard is plugged into the Mac Book Pro's one of the two USB ports, the Mini and mouse are plugged into the keyboard's USB ports. I have the interface plugged into the keyboard because my SFX Libraries are on my external USB hard drive and the Mac Book does not see it for some reason when it is plugged into the keyboards USB port.
Old 08-30-2010, 02:46 PM
Dism Dism is offline
Oh boy...
Never
plug any audio interface into a hub. On a keyboard, or otherwise. Only ever plug it directly into your Macbook.
Never use USB drives for anything with audio. Especially Pro Tools. Only thing USB drives are good for is transferring or backing up. Otherwise, leave it unplugged.
As a requirement for Pro Tools, you need a secondary drive for your sessions. This must be FireWire or eSata. Never USB. Sample libraries can go on your internal drive, but never on the same drive as your sessions. Ideally, you want them on a third FireWire or eSata drive.
Don't use the USB ports on your keyboard for anything other than a mouse, or small, low data, low power devices. iLoks go well in the other USB port. Don't try to run anything that needs power, or uses a lot of data, otherwise you are asking for problems.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 08-30-2010, 03:41 PM
All good advice from Dism.
Park
Old 08-30-2010, 03:46 PM
Thanks for the help, the only thing i dont understand is how am i running pro tools without a secondary drive, if its a requirement?
Old 08-30-2010, 03:49 PM
Griffin23 Griffin23 is offline
Its not required to use the software its just best, its recomended.
Doesnt mean it wont work its just means if something goes wrong or doesnt work you cant blame anyone.
Apple Macbook Pro 13" (2010)
10.7.3 | 2.4Ghz Intel C2D | 4GB RAM | 250GB HDD (Internal | OS) | Oxygen 8V2
Apple Mac Mini (2009)
10.7.2 | 2.0Ghz Intel C2D | 4GB RAM | 250GB HDD (Internal | OS) | 320GB HDD (External FW | Sessions) | 1TB HDD (External USB | Backup) | Axiom 49
M-Box 2 | ProTools 10.0.1 | Reason 5
Pro Tools 110 Qualified
Old 08-30-2010, 08:11 PM
It's a system requirement. It's listed.
Just because a computer doesn't meet all the requirements doesn't mean a program won't necessarily run... but it won't run well. Running sessions from the system drive creates an inevitable chockpoint. If you want the software to run at it's full potential, you need to fulfill the requirements. Speaking from experience, here.
D
Mouse and Keyboard set-up james21789 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-05-2010 05:37 PM
PT8 with just keyboard and mouse redchair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 10-05-2009 04:57 AM
Keyboard and mouse stop working during playback HotRats_Reloded Pro Tools TDM Systems (Mac) 9 05-18-2009 01:31 AM
Mouse Keyboard USB vs PS/2 yarrick19 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 06-18-2005 10:57 PM
USB MOUSE/KEYBOARD Abomb97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2003 06:13 PM
