Old 05-11-2009, 08:15 AM
HotRats_Reloded HotRats_Reloded is offline
Default Keyboard and mouse stop working during playback
Since this morning I've got this huge problem on our PT8 HD2 cs2 on MacPro (quad) OS X
Keyboard and mouse don't respond when PT is playing back the session,
they don't respond only on the PT windoew and they work perfecly on all other mac applications. So I guess is a PT related problem.
Keyboard and mouse don't react but the command are "stored" in the "mac memory" because if make an action (i.e. hit stop, make a selection, open a plug-in window, etc) nothing happens untill i stop playback using C24. Just after the session stops the actions I've made during playback take place.
Any idea?
Thank you!
Old 05-11-2009, 08:45 AM
gary_kesling's Avatar
gary_kesling gary_kesling is offline
Default Re: Keyboard and mouse stop working during playback
I'm dealing with the same problem and have posted it under another thread here.
It's your music, Make it
www.2catstudios.com
Old 05-11-2009, 08:59 AM
So I'm not alone...I don't understand why untill friday everything was working fine and now
Old 05-12-2009, 02:02 AM
I've discovered that this strange behaviour occours only whan the CME UF80 master keyboard is on (using both wifi or usb connection).
It happens also on the PT LE 8 rig we have in the small room so now I suppose is a CME problem.
Old 05-12-2009, 03:02 AM
update:
If we use Logic Pro the problem does not occour.
any ideas?
Old 05-12-2009, 10:11 AM
DigiTechSupt's Avatar
Do you possibly have video in your session with High Priority playback selected in Preferences?
Avid Audio Tech Support
Support FAQ
Old 05-14-2009, 03:02 AM
No, no videos involved.
I've checked the Quick time prority and is set to medium with "high qualitiy QT image" set to off.
thanx for the reply.
Old 05-14-2009, 11:27 AM
Was this working properly at some point?
Try this:
Go to MacHD>Users>your account>Library>Preferences>By Host and trash 'com.apple.midi.a bunch of numbers and letters.plist'.
Go to MacHD>Users>your account>Library>Preferences and trash 'com.apple.audio.audiomidisetup.plist'.
Empty the trash and restart, then see if everything is working.
Support FAQ
Old 05-15-2009, 01:45 PM
Yes, the CME keyboard (wich is brand new) worked perfectly with PT for the first two weeks.
On monday I'll try your suggestion and come back here to report.
Thanx again.
Old 05-18-2009, 01:31 AM
Problem solved,
thank you very much for you efficient support!
Keyboard shortcuts (like switching mix/edit windows) stop working RiF Tips & Tricks 8 05-23-2017 02:05 PM
Scroll behavior when you stop--stay where you stop, or go back to playback point? bashville Pro Tools 10 15 01-26-2013 05:56 AM
Mac External Keyboard and Mouse not working DougHarrison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-30-2010 08:11 PM
Keyboard shortcut stop working LarsB Pro Tools TDM Systems (Win) 0 05-27-2004 10:26 AM
Why did my Pro Tools Custom Keyboard stop working? CO2 Pro Tools TDM Systems (Mac) 2 09-18-2002 12:32 AM
