Old 12-01-2007, 02:24 PM
jlcnyc jlcnyc is offline
Default OT: no video signal on startup
Hey DUC
I posted at the Mac discussions last week - but no responses.
I'm using the MacPro with a Samsung monitor (225bw)
Recently, when I start my cpu, I get no video (black screen). the monitor screen flashes a message (between "analog" and "digital") and then the monitor power light starts flashing (similar to when the monitor is on but the cpu is off)
I assume the monitor is searching for signal. I have to crash the mac.... and usually on the 2nd or 3rd restart attempt, I get video. I've checked the cable connections (seems ok)I also attempted to reset my pram numerous times (but I never heard the second chime - curious)
Any ideas?
bad cable? bad video card? loose video card? (I also recently had airport extreme installed in my cpu, could this be a factor?)
thanks in advance
www.jeffreyleecampbell.com
Mac Pro 2.8 GHz Quad
16GB RAM
Apogee Rosetta 200/ UA LA-610
Genelec 8030A/7050b
McDSP, Waves, Sony, URS, Spectrasonics, BFD, Altiverb
Old 12-02-2007, 12:26 AM
Holly73 Holly73 is offline
Default Re: OT: no video signal on startup
I don't know if this helps you, but I had a similar problem recently. After taking the Mac Pro home from the studio, I had no video signal. I just opened the MP and tried to move the video card a little and then it worked again. The card seemed to sit firm in its slot, but it still worked to fix the problem like this.
 MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire
Old 12-02-2007, 03:26 PM
I'll give it a try
thanks
16GB RAM
Genelec 8030A/7050b
Old 12-05-2007, 09:58 AM
still no luck
I've checked the video card - seems seated securely (I jiggled it)
I've reconnected the cables numerous times
i have to restart my mac 2 or 3 times before I get video signal
I'm confused...
since I am eventually able to get signal, what does that suggest?
any help is greatly appreciated
thanks
16GB RAM
Genelec 8030A/7050b
Pro tools startup - scanning for Video hardware - how do I get rid of that? anguswoodhead Pro Tools TDM Systems (Mac) 1 06-01-2011 06:28 PM
[B]Video Engine - How do I remove from Startup sequence[/B] DrFord Pro Tools TDM Systems (Mac) 0 01-15-2009 09:35 AM
Video Camera Signal pmueller VENUE Live Sound Systems 4 01-13-2009 12:38 PM
OT - question about splitting video signal keithl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-25-2004 11:36 PM
Video Signal Through Audio Snakes? relaxo Pro Tools TDM Systems (Mac) 2 10-24-2003 08:49 AM
