Could use some midi tips for EZ Drummer...
A friend of mine wants me to record some songs for him using his Roland Vdrum kit. It's the TD20 module and sounds pretty good, but imo not as realistic sounding as my EZ Drummer software. What I'd like to do is have his drummer play on the Roland kit and record to midi tracks which will somehow trigger EZ drummer's sounds. I don't need him to monitor via ez drummer. I just need the info into PT so when I play back, it's EZ drummer I'm hearing.
My concerns are: -I have no idea how to do this (sad) - The Roland's hh is variable so how do I get that to trigger the appropriate samples in Ez Drummer. If anyone can give me some good ideas on this, I'd appreciate it. tks, Steve |
Re: Could use some midi tips for EZ Drummer...
I've tried exactly this, with REASON. I haven't been able to get it to work without latency. One thing I tried was having the drummer monitor his performance at the TD10. He hears his own roland sounds. Then i capture his midi performance nad 'play' reason drums. I've always had glitches. almost all of the midi data gets ported accurately, just with latency.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002) |
After you record his performance, just set up an instrument track with eZdrummer. Then, on the output of the midi track you recorded, set it to ezdrummer's input. Done.
If some of the notes trigger the wrong samples, just go to the midi track and drag them to the correct spot. You can select all of the same notes on a track if you want to drag them all to a new note that will trigger the correct sample. |
EZ Drummer/MIDI Notes Disappear? | RokVox | Virtual Instruments | 37 | 10-22-2012 02:59 PM |
DFH Ez Drummer dragging midi files in and midi maps??!!! | Dualchambers | Pro Tools M-Powered (Win) | 1 | 09-01-2012 04:47 AM |
midi controller not working with ez drummer | alzuka | MIDI | 3 | 08-18-2009 07:50 PM |
Midi loops/ez drummer | johnnyz | MIDI | 1 | 04-06-2008 10:21 AM |
ez drummer midi region question | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-20-2007 08:47 AM |
