MP3 option Authorisation problem
Hello
I just installed my Protools 7 on a second drive (same computer). When I want to authorize my MP3 option the code is not accepted. I have two codes, but none of them work. (the authorisation code worked within 6.9.3 and PT5 version) I installed the mp3 codec update from CD, but this doesnt help. The code is not accepted Alex
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
Re: MP3 option Authorisation problem
anyone?
To install on Mac OSX when you have problems with the MP3 Option you'll need to do the following:
Run the Pro Tools 7 HD, LE, or M-Powered installer application again Put a check mark ONLY in the box next to "MP3 Codec Update" Uncheck ALL other check boxes, including the Pro Tools check box Follow the prompts in the installer application Installing the MP3 Codec Demo first, then installing the MP3 Codec Update also works. You may also need to update to the latest version of the PACE InterLok drivers |
Problem solved!
Authorisation was not possible even after installing mp3 codec update from CD So I have copied the file "activations.txt" from my working 6.9.3 installation to the Protools7 partition. path: user/name/Library/Preferences/Autorisation Preferences/activations.txt This solved my problem. All is working now Ale
I also have this problem. So, I copied the file from the old G4 with 6.9.3 installed. But, on the G5 there's already a file called "activations.txt" in the folder. How can I do this? Can I just merge these two files somehow?
Thanks in advance.
First try the installation troubleshooting suggestions here:
www.digidesign.com/download/mp3
Administrator Avid Pro Audio Community |
I deleted the codec folder and I did a fresh install including codec update.
Protools did not accept my codes. So i replaced the activations.txt with the file from my old installation. Sometimes things work that should not work ???? Ale
MP3 OPTION authorisation lost with 6.9! | crizdee | Pro Tools TDM Systems (Mac) | 8 | 12-05-2018 08:07 AM |
i lok authorisation problem please help | Huwmorgan | Windows | 2 | 02-03-2013 10:17 AM |
Sudden authorisation problem | Gerontius | Pro Tools TDM Systems (Mac) | 0 | 01-21-2010 05:04 AM |
MP3 Option Authorisation Code | Loophole | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-11-2004 09:20 AM |
Authorisation problem | Bar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-02-2004 06:22 AM |
