  #21
Old 10-25-2014, 09:42 PM
confusedhelp confusedhelp is offline
Default Re: Over 250 Xpand2 Patches FREE
Originally Posted by DonaldM View Post
I've looked and looked and can't figure out where I need to put Chris's folder of patches so that they will show on the Xpand2 patch menu. There's nothing in the manual to tell you either. This can't be that hard. Where do we put the expansion file?
Originally Posted by ankely View Post
Nick,
Put the whole folder, Xpan2patches, into the Xpand2 folder inside the Plug-In Settings folder:
Windows:
Program Files\Common Files\Digidesign\DAE\Plug-in Settings
Mac:
Library/Application Support/Digidesign/Plug-in Settings
Sorry I'm not on a PC but this way of doing it should be the same right? Try it!
  #22
Old 10-26-2014, 01:08 AM
demodigi demodigi is offline
No, the file locations you posted are for Pro Tools 10 or less.
For Pro Tools 11, Xpand2's plug-ins settings folder is located, by default, in :
- Mac : /Documents/Pro Tools/Plug-Ins Settings/
( fullpath => /Users/[Login]/Documents/Pro Tools/Plug-Ins Settings/ )
- Win7 : I suppose it is also inside \Documents\Pro Tools\Plug-ins Settings\
( I don't the default fullpath name )
This location can be changed (and found) in Pro Tools' Preferences (Tab "Operation", Section "User Library").
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD)
MacMini (Core i7 Quad@2,3GHz RAM16GB SSD)
PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP)
PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP)
PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD)
PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD)
RME UFX (USB2 with MM and Firewire with MBP)
+ Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1
  #23
Old 10-26-2014, 12:22 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Yes, that is correct as I discovered last night. No wonder I had such a hard time finding it. Oddly, it isn't mentioned in the manual at all...at least not that I could find. So on Windows it is Users/UserName/Documents/ProTools/Plug-ins Settings/Xpand!2 The way I found it was to create a patch of my own, and then do a "Save As" within Xpand (the very top of the Xpand window is the pulldown menu) to see where that file was being put...and there it was!
What I did was rename this new patch bank "ChrisD Patches" and then put the entire folder in the "Xpand!2 folder, and then it shows up at the bottom inside Xpand's list of patches. I also have a folder named "My Patches". Both are there in addition to all the Xpand folders.
So that's what you have to do in Windows.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
  #24
Old 10-27-2014, 06:55 PM
Question. How do you guys find the quality of the sounds of Xpand2 compared to other virtual romplers? I haven't had the chance to play around with the soft synths that are out today.
  #25
Old 10-28-2014, 06:19 AM
DonaldM's Avatar
Well, when you have some 2500 or so sounds, which is what Xpand2 comes with, you're going to have some that are mediocre and others that just great, and that is true with Xpand2 as well. There are certainly a number of really nice sounds to work with in several categories, and because you can layer up to 4 at once, you can get some nice rich, thick sounding pads. And you do have some good basic editing features (filters, envelopes, resonance mainly) and basic arps and fx. Its nice too, that you can create you own sounds with it and save them as patches for future use. As ROMplers go, this is definitely one of the better ones in my opinion.
  #26
Old 10-28-2014, 08:46 PM
If you had to compare it to all the other 30 VI's that you own, how would rate it in terms of quality? Seeing that you own Omnishpere, Nexus2 etc.
I honestly have only used Xpand2, so I'm not sure if I'm missing out on anything.
  #27
Old 10-29-2014, 02:16 AM
chrisdee's Avatar
chrisdee chrisdee is offline
I reccomend trying out Nexus2 and some of the expansions. It's head and shoulders above Xpand2! in my opinion.
A couple of other VI's to try out is Sylenth1 and Zebra/Diva.
  #28
Old 10-29-2014, 12:02 PM
DonaldM's Avatar
I don't think its a fair comparison. Xpand2 is a freebie that comes with PT. The question was are the sounds good. Some definitely are. I wouldn't try to compare it with something you'd buy extra, like Nexus2 or Dune2 or Sylenth, etc. Like ANY VI, if it has the sound you want for your mix...use it!
  #29
Old 12-13-2014, 08:31 PM
mmdrummer mmdrummer is offline
I know this is a very old post... but does any one know where I can still get the 250 xpand2patches... The old link no longer works. Thanks [email protected]
  #30
Old 12-15-2014, 05:58 AM
chrisdee's Avatar
I'm afraid I didn't keep the old presets I made, but I have made new/updated ones available at http://dillner.net/protools/Xpand!2.zip
Maby RussUK has the old ones I made somewhere on his server?
No Xpand2 patches after PT 10 update dmichael Virtual Instruments 5 10-12-2012 10:28 PM
Xpand2 patches missing! iamkimosabi macOS 1 06-07-2012 11:37 PM
Getting Rid Of Delay On XPand2 Patches epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-05-2009 08:29 PM
Xpand2 Patches - The Monster Set! RussUK Virtual Instruments 7 01-20-2009 08:20 AM
Xpand2! patches vs parts chrisdee Virtual Instruments 2 11-29-2008 12:59 AM
