Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 10-24-2017, 07:24 AM
bucha bucha is offline
Default BUG : No Sends Titles
Hi guys,
I see this bug very often and it's a bit boring.
Open a session and all the names of the sends are blank on the S6, but they are active and in the right order, they just don't have any names on the console.
Just installed the V3.7 and it's still here.
Old 10-25-2017, 11:50 AM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
Default Re: BUG : No Sends Titles
I just noticed this behavior as well when instanciating a Send using the Track name shortcut which creates a new bus named after a targeted track.
Can you please let us know what scenarios you are seeing it in and if you have a recipe to make it fail consistently so we can get it fixed? Thanks much.
Jeff
Jeff Komar
Old 10-26-2017, 08:19 AM
Hey Jeff,
No shortcuts and no recipe to reproduce this.
It happens in sessions created/or not with an S6 attached to the Protools.
Sends are created whith the Alt+Shift keyboards shortcuts to create them massively.
I don't think it's coming from a shortcut.
I only open the sessions and sometimes the LED displays where the titles are supposed to be remain black.
I then quit the PT and relaunch it (which can be long …), and it generally solves the problem.
Old 10-26-2017, 08:39 AM
Understood, thanks. We will investigate and get it fixed.
Jeff
Jeff Komar
Old 06-03-2020, 12:12 AM
Gregor B. Gregor B. is offline
I still get this today.
no send names are displayed on the LCD monitors and neither on the S6 knob modules. I only see values. This occurs more often than it doesn‘t, but don‘t know how to reproduce it. Restarting S6, restarting WSControl, restarting Pro Tools won’t fix it.
Whenever this bug happens, I also don‘t see any any options like Object toggle or output bus when I click on „Bus“ in the processing module.
I‘m on PT 2019.10.0 HDX, S6 19.12.1.23
Any thoughts?
Old 06-03-2020, 09:38 AM
quadraphonics quadraphonics is offline
I also see this. Usually happens when switching between multiple sessions with different send layouts. Since most of my work is done from one template, I don't see it that much.
Saving and quitting solves this issue.
Any thoughts?
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Bouncing to disc while keeping your titles? SteveGarman macOS 0 11-09-2014 11:34 AM
Problem ~ mixed-up titles... and more! BionicDan Avid Scorch (iOS) Forum 8 07-26-2011 03:01 AM
CD Titles Missing Earl D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-11-2006 07:14 PM
The use of the LFE track for DVD titles TheVectorWarrior Post - Surround - Video 10 01-13-2004 09:24 PM
