Old 04-03-2003, 12:02 PM
dmaxj dmaxj is offline
Default PRO TOOLS & MIDI CONTROLLERS
Is there a way to control the faders in PRO TOOLS via an external synth controller.
I have six controller knobs on my synth. I would like to be able to control the faders in PROTOOLS with my synth through MIDI.
I know I can do this in Cakewalk, but I have no clue for PT...
Also, is there some kind of driver that is available, so MIDI communication occur between two software applications on the same computer??? You know, something like the VIRTUAL MIDI ROUTER that comes with soundforge???
Peace
Old 04-03-2003, 03:18 PM
hurdy gurdy hurdy gurdy is offline
Default Re: PRO TOOLS & MIDI CONTROLLERS
Hi Dmaxj,
If I'm not mistaken your controller must be able to "emulate" or be programmed to one of the supported control surfaces for Pro Tools- such as the CS10 or Mackie HUI--if it can emulate such MIDI protocol, you could use it for a controller.
I would check to see if your controller is programmable then check the Pro Tools Midi Controllers Guide (appendix a) for programming and "Using Other MIDI Controllers".
Good Luck!
LB.
Are there Pro Tools 10 compatible MIDI controllers? EmperorMusic Pro Tools 10 33 02-18-2012 12:23 PM
Using 2 MIDI controllers in Pro Tools 9. GraemeLittle MIDI 3 09-18-2011 09:09 PM
USB MIDI Controllers With Pro Tools LE 8? steals 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-07-2010 08:52 AM
midi controllers and pro-tools, help pls ! revere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-13-2008 03:36 PM
Legacy MIDI Controllers for Pro Tools 6.9 Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-09-2005 08:06 AM
