Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
  #21
Old 12-19-2019, 04:54 PM
octatonic octatonic is offline
Default Re: 2019.12 Discussion
Working great on 2019 Mac Pro.
  #22
Old 12-19-2019, 04:55 PM
innesireinar innesireinar is offline
Originally Posted by jasonkalman View Post
Just my opinion, but if you are in the middle of a project and you don't have the time to mess with workarounds or plugin issues, I would stay put on Mojave PT 2019.10. No sense in doing QA work for Avid when you have work to do. I have no idea which plugs are 32 and which are 64 and quite frankly I don't care. I figure all of this will be sorted out by the middle of next year (3rd party companies should all be compatible by then) and Avid should have a more stable version for Catalina. Right now there are too many known issues. I read the release notes and it was mostly a laundry list of known issues. That doesn't give me any confidence to update at the moment. I would say, if you are running fine on Mojave, update at your own risk, good news is you can always revert back to Mojave and PT 2019.10 so in that sense, it really isn't a huge issue, just time potentially wasted.
In my opinion the way to go is to have two separate partitions. One for working and the other for testing new stuff
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2019.12 - Cubase Pro 10
Mac Pro 5.1 quadcore 2.8 16GB Ram - Mac OS 10.13.6
  #23
Old 12-19-2019, 05:17 PM
PasteEater PasteEater is offline
Just installed 2019.12 on a brand new (cheesegrater) Mac Pro. PT seems fine for strictly audio workflows, but it's nearly useless for me, as I do post-production and need the video abilities to work. Anyone heard any rumors of when PT will be fully compatible with Catalina? I obviously can't downgrade the new machine to Mojave, so I'm stuck doing all of my production work on my old Mac Pro trashcan. It's like getting a new Ferrari, driving it around the block and parking it in the garage to sit.
  #24
Old 12-19-2019, 05:29 PM
audiobob's Avatar
audiobob audiobob is offline
You can install 2019.12 on a Mojave machine and not have to worry about the 32/64 issues. You don't need Catalina to run it. I did on a 10.14.6 Mini and it's working fine so far. Have both 2019.10 installed as well just in case.
  #25
Old 12-19-2019, 05:34 PM
21 Junipers 21 Junipers is offline
I know this doesn't answer your question, but I saw a note from Pro-Tools Expert regarding using "Video Slave 4" to address this issue.
I followed their link and noticed the vendor offers two versions. It looks like there are demo versions for both Video Slave 4 and Video Slave Pro. You can subscribe or buy a perpetual license.
Might be an option for you or somebody else. Disclaimer: I have no relationship to Pro Tools Expert or the software vendor. I have not uses/tested. Simply trying to be helpful.
  #26
Old 12-19-2019, 06:45 PM
Southsidemusic's Avatar
tried 3-4 songs with 125-150 tracks with somewhere around 50 VI and as usual alot of automizations and plugins but many bounce’d audio aswell with the awesome outboard gear and 2019.12 runs like a champ on both Trashcans with 10.14.6 and 10.13.6 both PT Ultimate and 12 core 64GB Ram with 1TB internal SSD’s and Tbolt SSD’s.
I should mention half of the plugins are UAD-2 and runs DSP from X8P’s and Satellite Octo and Quad.
Best Regards
Christopher
South Side Music Group
WEBHOME
  #27
Old 12-19-2019, 08:16 PM
grayter1 grayter1 is offline
No issues here. I'm trying to break it with Omnisphere, and while the CPU usage is still higher than I'd like, after a cursory look, it appears to handle VI's a bit better.
This is all anecdotal, of course. YMMV...
tg
Win 10 Pro / i7-6700K 4.00GHz / GA-Z170X-UD5 / 32 GB / nVIDIA GTX 1050ti / Audient iD22 / Komplete S49 / Pro Tools Ultimate 2019.6 / Nuendo 10 / Reaper 5 / Studio One 4.5 / Komplete 12
  #28
Old 12-19-2019, 08:51 PM
We run 2019.12 ultimate on macOS 10.13.6 and I even tried on Sierra 10.12.6 and worked grrrrrreat!
This version looks very promising as long as you dont have Catalina and do video.
Best Regards
Christopher
WEBHOME
  #29
Old 12-20-2019, 06:57 PM
Pingafuego Pingafuego is offline
Originally Posted by nedorama View Post
installed and after updating all the plugins through Avid Link, I'm getting the dreaded solid blue Stop and flashing green play. Will trash preferences and try again, both with Eleven Rack and internal speakers. If that doesn't work I'll delete Pro Tools and do a fresh install.
Update - Internal speakers work fine, it's the Eleven Rack. Will see online if Focusrite Scarlett 2i2 v2 is supported and may need to switch to that.
Hopefully the Eleven Rack drivers are updated shortly, but I know that it was time for a new I/O in 2020...
Did you upgrade the OS to Catalina? Is the Eleven Rack compatible with the new Pro Tools Version?
Thanks
  #30
Old 12-20-2019, 07:11 PM
Thanks
Yeah tried on my personal Mac Pro as our new 2019/2020 Mac Pro’s are do for delivery Jan 3rd and we needed to know what works and what doesn’t in this initial release as the new Macs comes with Catalina. We ran it on a new SSD drive.
And Eleven Rack is a no right now.
http://duc.avid.com/announcement.php?f=&a=135
Best Regards
Christopher
WEBHOME
Pro Tools 2019.10 Discussion TOM@METRO Pro Tools 2019 94 12-05-2019 02:51 PM
Install pro tools 2019.10 over 2019.6? Clarkston Guy Pro Tools 2019 6 11-01-2019 09:12 AM
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 09:30 AM
The -20 dB discussion Syncman Post - Surround - Video 10 11-12-2003 10:53 PM
