Old 10-23-2011, 10:55 AM
sjsG sjsG is offline
Default External clock w/ 3 interfaces
Hopefully a simple question for you guys, when connecting my isochrone ocx to my 3 192s, can I set up a sync loop like with the internal clocking or do I use separate outs from the ocx to each ext clock in on each interface? Im hoping I can daisychain but im not sure how the loop would work since theres no in on the ocx. Thanks!
Old 10-24-2011, 08:46 PM
Default Re: External clock w/ 3 interfaces
anyone?
bump
Old 10-24-2011, 08:51 PM
Craig F Craig F is offline
you loop the 192s
you drive the first 192 from the ocx
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 10-31-2011, 05:24 PM
Thanks for the reply!
Old 11-01-2011, 05:25 PM
AAR AAR is offline
I think the best method to clock your interfaces would be to "Star Clock" them with the ocx. Connect one WC output from the ocx to each WC input on each interface.
In Session Setup Page, set each interface to clock to "Ext WC" with the correct sample rate, then set the Sync IO if you're using one to Ext WC or Vid ref.
This is the most stable and reliable Clocking method.
Of course sample rate changes will need to be made from the ocx and not PT anymore, as the ocx has now become the "Master Clock," not the individual interfaces.
Hope this helps!
Old 11-01-2011, 05:37 PM
Star works but I've had problems with it in the past
Loop is much more reliable
Thank you,
Craig
Old 11-01-2011, 09:11 PM
RTFM RTFM is offline
If you want an additonal opinion on that - I'm with Craig on this one.
External Clock in 7.4 wh3music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-11-2008 06:05 PM
DM2000 and Pro Tools Interfaces Word Clock Problem joepopp Pro Tools TDM Systems (Mac) 52 04-01-2008 11:13 PM
HD clock or external clock Beegster Pro Tools TDM Systems (Mac) 25 10-03-2002 11:01 AM
192i/o Internal Clock vs. Other External Clock everglass Pro Tools TDM Systems (Mac) 1 08-27-2002 09:51 AM
How many interfaces without external clock? Allan Speers Pro Tools TDM Systems (Mac) 5 07-04-2002 03:47 AM
