Old 01-19-2009, 06:03 PM
AAR AAR is offline
Default ProTools 8 - Video Satellite Connection Error ?
I was wondering if anyone else has had this problem:
System:
2.8ghz 8 Core Mac
OS: 10.5.5
4GB Ram
Magma PCIe-PCIx Expansion Chassis with HD3 installed
PT: version 8
I have the computer network connections configured for Aggregate Ports to enable faster network transfers. When Protools launches, I receive a notification stating: "No valid network adaptor is available for Video Satellite connections."
I never installed the Video Satellite Option when I installed version 8.
I've turned off every Satellite function available in Preferences.
This happens whenever you open peripherals as well. Is there a way to disable this?
P.S. I've confirmed this "aggregate port error" by going to a standard "single port" network configuration and all was well.
Anybody have any ideas?
Old 01-20-2009, 05:24 AM
eastwind eastwind is offline
Default Re: ProTools 8 - Video Satellite Connection Error ?
The brand new update 8cs1 fix this problem.
Mac Pro Quad 2.66ghz / PTHD2 - 8.0.3cs2 / MacOS 10.6.3 / Apogee Rosetta 200 + X-HD / 5 Gigs Of RAM
Old 01-30-2009, 11:44 AM
welchis welchis is offline
No...I installed 8.0.1cs this morning and I am still having the same error...disabled all video satellite prefs as AAR did and still get error every launch.
Any other wisdom out there?
Old 01-31-2009, 10:26 AM
bassie12 bassie12 is offline
I'm having the same issue. The error dialog also shows up every time I access the peripherals setup. Strange....
"It's gonna be Great!!!"
Old 01-31-2009, 05:56 PM
Oroz Oroz is offline
Hi, I have the same problem and here's a reply from Digi:
You can click OK with no harm.
The message will not appear if you are connected to a network (i.e. you have a valid IP address).
We are investigating how to resolve this issue such that this will not occur if you are not currently connected to a network.
Bob Brown
Digidesign Principal Engineer
Old 02-28-2009, 07:34 AM
carlos santana carlos santana is offline
im having the same issue please advice
protools 8 cs2 hd accel 2 pcie mac osx leopard 10.5.5 ppc g5 quad 2.5ghz 4.5gb ram
250 system (transfer only) internal
250 firewire backup (transfer only) external
250 usb backup (transfer only) external
80 gb recording drive (rec) internal
96io
Old 05-25-2009, 03:48 PM
Tweakhead Tweakhead is offline
This is driving me NUTS,
Digi, please FIX IT.
Old 05-26-2009, 08:20 PM
Seriously. Is there some .bundle file or .framework file I can remove to get rid of this message?
I don't even want this Video Satellite capability.
Old 05-27-2009, 10:53 AM
DigiTechSupt's Avatar
This is high on the list for a fix.
As always, though, I cannot predict when the fix may be available.
Avid Audio Tech Support
Support FAQ
Old 05-27-2009, 11:20 AM
OK. Thanks for the response.
Satellite Link & Video Satellite Link error on Pro Tools 9 HD 9.0.3 billegates macOS 0 09-24-2013 03:28 PM
"Video Satellite Option 1.0 - Authorization Error" - without Video Satellite Matts macOS 7 06-29-2011 09:32 AM
Protools 9 w/complete and Video Satellite Le twisterpants macOS 1 01-05-2011 01:02 PM
ProTools and Avid Satellite connection problem tfa Pro Tools TDM Systems (Mac) 2 06-02-2010 01:47 PM
ProTools and Avid Satellite connection problem tfa Post - Surround - Video 6 06-02-2010 01:46 PM
