Old 01-05-2006, 02:58 PM
Richard Conrad Richard Conrad is offline
Default How are people dealing with noisy G5\'s?
Hello all,
just putting this out there, in case someone has a miracle solution.. Like many of you, I too have a Powermac G5 (pre-dual core), and it's loaded with RAM and a pair of internal hard drives. Has anyone else noticed that these computers have a certain "aircraft carrier" quality, in that they make a horrendous amount of noise when operating?
I've had a listen to several other machines, and even when running at stock specs from the factory, they're bloody loud. My question is rather simple... besides isolating the computer in another room, is there anything I can do to tame the noise (i.e. internal settings, aftermarket parts, isolation boxes, etc)? It sounds as if the fans are going full-out from the get-go, and I just want to know what I can do to deal with this issue.
as always, input is greatly appreciated.
Richard
PMG5 [4GB Ram / Dual 74GB WD Raptors] / HD1 / PT 7.1cs2 / 192 IO / Apogee Big Ben
Old 01-05-2006, 03:22 PM
c-tone c-tone is offline
Default Re: How are people dealing with noisy G5\'s?
You gave your specs, but not the model G5. I have a dual 2.0 G5, and it is quieter than my G4 933 QS. The only time I have heard the fans rev loud was during disc burning.
Go to the Apple user discussions board for more info.
www.clifnorrell.com
Old 01-05-2006, 03:58 PM
jordi jordi is offline
Check the system preferences and check it is set to best performance, if not it will be more noise the normally when using ProTools.
I hope this helps...
Jordi
Old 01-05-2006, 04:19 PM
roberts roberts is offline
Dead Quite .. in my cooled machine room! It make a big difference in the CPU Temp.
Old 01-05-2006, 05:07 PM
It's a dual 2.0, and it's much louder than my QS 867 was.. I'll try their user forum and see what my other options may be.
cheers,
Richard
Old 01-05-2006, 05:31 PM
AAR AAR is offline
check this out.....
http://www.buyaudiogear.com/whisperrack.cfm
Old 01-05-2006, 07:11 PM
Jakeman Jakeman is offline
Sounds to me like a G5 problem cause my G5 2.0 GHz Dual processor is the quietest computer I've ever used in the last few years. Try this and see if that helps or if the problem persists.
Old 01-05-2006, 08:04 PM
It was the SMU that needed to be reset.. now she's near-whisper quiet (well, as quiet as a computer can be). Thanks again to everyone on the DUC for all of your help!
Richard
how are you dealing with this? Anibal Pro Tools 10 0 01-14-2014 12:07 PM
Dealing with some noise DonaldM Tips & Tricks 8 09-05-2008 01:05 AM
Dealing with Phasing in my mix calibos 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-20-2007 03:09 PM
Dealing with AAF files?????? Naylorfreak Post - Surround - Video 3 08-20-2006 10:59 AM
dealing with noisy tracks / mumbling leads viaspiaggia Post - Surround - Video 3 06-24-2004 08:28 PM
