  #21
Old 10-02-2016, 01:10 PM
TOM@METRO's Avatar
Default Re: Midi Latency Problem welcome back in 12.6 :(
I don't think it's a question of hate, it's just that post and broadcast have been the higher priority. I find MIDI in 12.4 a bit more solid.
~ tom thomas
Formerly hobotom
Pro Tools Ultimate 2019.12 HDX
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #22
Old 10-02-2016, 01:23 PM
Shan's Avatar
Shan Shan is offline
Originally Posted by del cosmos View Post
So, its broken right?
Yes.
The workaround I also posted isn't exactly a usable solution either. If you remove/add plug-ins, or do anything that changes the max plug-in delay value, then you'll have to go into Global MIDI Offset and change that value manually every time.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
  #23
Old 10-02-2016, 03:05 PM
mykhal c's Avatar
mykhal c mykhal c is offline
what's steps for repro on this bug?....
plugs with latency in session then play VI and watch where data is placed? and is the late placement = to the session and/or plugin delay amount?
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #24
Old 10-02-2016, 03:45 PM
Shan's Avatar
Create a session with an exaggerated long delay for the purpose of seeing the issue. Don't use the Time Adjuster plug-in to do this, as it still has that years old bug of not displaying the delay in the track. I just used Maxim for testing purposes:
Play something simple and be accurate with your timing. I hit one note on my controller every second quarter note. Next, look at your performance and notice how bad you really weren't when you played it:
Adjust the Global MIDI Offset and match it to the plug-in delay:
Do the above steps again and you'll noticed it's closer to your performance:
I ran no tests to A/B the maximum plug-in delay vs system delay for the Global Offset value. Avid can do that when they sort it out.
If you really have time to burn, you can run the above test using a hardware synth and record audio from it along with the MIDI data to compare. Avid should be doing that on their end.
Shane
  #25
Old 10-02-2016, 03:53 PM
mykhal c's Avatar
thanks Shane!
also...you have 'compensate after record' selected in your I/O since you are HDX, correct?
  #26
Old 10-02-2016, 04:03 PM
Shan's Avatar
thanks Shane!
Tested on HD Native and also tested using the ASIO4All v2 driver.
Shane
  #27
Old 10-02-2016, 04:13 PM
mykhal c's Avatar
Shane
got cha...but you still have this selected in your I/O right?
  #28
Old 10-02-2016, 04:17 PM
Shan's Avatar
Always enabled.
Shane
  #29
Old 10-02-2016, 04:21 PM
mykhal c's Avatar
Always enabled.
Shane
thanks again...
  #30
Old 10-02-2016, 10:34 PM
mykhal c's Avatar
could be my meter...but i'm seein' the placement off by half of the system delay. regardless still broken tho...
PT9 midi/latency problem, need help funkpower macOS 1 04-21-2011 07:47 PM
latency with midi out and audio back in... stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-23-2006 12:06 PM
Midi play back problem batch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-16-2004 11:23 PM
midi and latency problem with 002.. Jayson Torres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-10-2003 10:25 AM
Latency When Playing back MIDI JSXtremist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2003 10:54 PM
