Old 09-10-2007, 12:10 PM
AAR AAR is offline
Default PT 7.3.1cs4 Command 8 Bug
PT 7.3.1cs4 does not recognize the Command 8. In the peripherals menu under Midi Controllers when you select the Command 8 there are no Receive or Send ports to select thus it can't communicate. I have tried this with a couple of different computers a Mac Pro and a G5 Dual 2.3 Ghz PowerPC. I then reverted back to 7.3.1cs3 and everything appears to be ok. Then just to make sure I went back to 7.3.1cs4 and I'm unable to select the ports. I use OS 10.4.8. Has anyone else had this problem?
OS X.4.10 & PT LE 7.3.1cs4 Craig Woolard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-10-2007 04:04 PM
Mac OS 10.4.10 and Pt 7.3.1cs4? logandrum Pro Tools TDM Systems (Mac) 2 07-30-2007 11:13 AM
Mac OS 10.4.10 and Pt 7.3.1cs4? logandrum Pro Tools TDM Systems (Mac) 0 07-30-2007 01:21 AM
QT7 + PT6.4.1cs4 + OS 10.3.9 = OK? JR Fountain Post - Surround - Video 4 03-09-2006 09:01 PM
PT MIX 6.4.1cs4 who's using? agock Pro Tools TDM Systems (Mac) 10 07-31-2005 06:10 PM
