Old 08-06-2006, 12:55 PM
French links French links is offline
Default Plug ins chain
In which order would you put your inserts?EQ,Comp,Gate.
Thanks
Old 08-08-2006, 02:54 AM
Chris Cavell Chris Cavell is offline
Default Re: Plug ins chain
Depends on the track and to a certain extent personal preference. There's no right or wrong answer...just make sure for the given track that you can justify your choices logically. The titile "engineer" means that you should be able to work out what's best for the situation.
Cavell Studios
Old 08-08-2006, 04:44 AM
mindnoise mindnoise is offline
HI,
add. to the above try reasoning something like this:
1st Gate - to eliminate what should NOT be processed.
2nd EQ - to work on what should be audiobly be colored (boosted or cut)
(changing the Freq. will change the sound color)
3rd Comp - to work on the dynamic pressure to match something else´s level or dynamic.
this is just an example. It really depends on what you want to achieve.
maybe take a look the this:
http://www.theprojectstudiohandbook.com/directory.htm
to learn more about the WHAT AND the WHY you should do it.
regs
last: PT11.3.1
Old 08-09-2006, 11:32 PM
badboymusic badboymusic is offline
I prefer to put my eq after the compressor so the compressor is adjusting off the original sound and then eq to taste. To my ear it sounds more transparent in most cases, but not all. I agree, no right or wrong way, try both and see which you like better.
Old 08-09-2006, 11:41 PM
music project music project is offline
can I save a plug in chain that i like to be recalled on another session ?
or do i have to insert them one at a time and load a preset to every one of them?
2009 8 core mac pro "nehalem" with 6GB ram, 002R, command 8, pt 10.3.5
Old 08-10-2006, 03:53 AM
HI music,
unless you use some sort of reference (template) session to start with it´s
your second guess.
regs
PS:sorry, Chris´s reply below is right, I stand corrected.
last: PT11.3.1
Old 08-10-2006, 04:53 AM
You can always import a track from a previous session sans audio, then move or copy the new audio into that track.
Cavell Studios
Plug-in upgrades/mastering chain advice? sparky3000 Post - Surround - Video 3 06-12-2013 03:22 PM
Side Chain Arriving Late to RTAS Plug - Delay Comp On holden Pro Tools TDM Systems (Mac) 33 04-23-2012 11:51 AM
Master Plug-in Chain reycantong Tips & Tricks 34 12-06-2009 01:45 AM
What's Your Plug-In Chain on the Master Fader??? CraigD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 22 04-14-2004 10:12 PM
Proper Plug In Chain "order" for Voice work and Mutimedia bit depth outfit Pro Tools TDM Systems (Mac) 0 11-01-2002 05:22 PM
