Old 05-13-2016, 04:37 PM
Trainwreckmusic Trainwreckmusic is offline
Default I am over Apple thinking of moving back to windows advise needed.
I have had it with Apples new overpriced non user upgradeable computers & bloated OS systems.
I own a PT10-11-12 perpetual license,
I have been running Apple hardware & OS & PT since LE7 (2009)
I am currently running OSX 10.8.5 and PT 10
I am seriously thinking about going back to windows & PC.
But all of my sessions are PT 10 saved on Apple OS formatted external glyph hard drives.
Am I going to have issues accessing these sessions on a new PC?
What other problems am I going face moving back to PC?
Eventually I will install PT 12. whatever.When ever it is remotely stable.
Thanks
TWM
2009 Mac mini 2.53 Ghz 4Gb ram OS X 10.8.5
ProTools 10.3.10- runs rock solid!
2012 Mac Mini 2.6 i7 quad core 16Gb ram 256 SSD
OS Sierra 10.12.6 PT 2018.4 its mostly working for me!
RME FF800, Presonus Digimax 48K & LT, Central station, KRK Roc kit 8v2, KRK Rockit 10s, a plethora of outboard gear …Too many vintage guitars & amps to list!
Old 05-13-2016, 05:47 PM
The Weed's Avatar
The Weed The Weed is offline
Default Re: I am over Apple thinking of moving back to windows advise needed.
See the first page of the i7 Thread above or contact Steve (guitardom) at pro-tools-pc.com. Purpose-built Windows computers from people who know what they're doing and talking about with extraordinary after-sales support. And no, I don't work for them, although, during a Toronto winter, I would like to live in New Mexico
If the PC is properly specced and optimized all should good.
As to your hard drive question, IIRC, you should be able to use MacDrive or similar to use/move the sessions or I believe Paragon Software has a solution. Others will know much better than I.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-13-2016, 05:58 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
You can get Mac disk drivers for PCs. I use Paragon. I've had no trouble other than with a few ten year old drives that our MacBook Pro also can't read.
I highly recommend the Pro Tools PC for a ready made machine tested and optimized for Pro Tools. http://www.pro-tools-pc.com. It just sits here and quietly works.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Old 05-13-2016, 06:49 PM
Steve@ZooWest Steve@ZooWest is offline
Until I work out a more elegant solution (and it may not ever be needed), I've been copying session folders to a USB3 flash drive on the Mac and transferring them to my PC. It's been working well, at least for my situation.
If I had to transfer all the TBs of sessions that are archived, this would be a bit wearisome, but such is not the case.
"Modern manufactured music is like art they sell at a furniture store."
http://www.weddingmusicproject.com/
http://www.weddingmusicproject.com/w...music-samples/
http://stevemillikan.com/
Old 05-13-2016, 07:04 PM
Yes just move 'em over via some interchange media, or file sharing and drag 'em all over. If you are giving up on Apple there is no reason to add HFS+ compatibility to your Windows PC. If you are in a mixed environment then what Bob mentioned can be great.
Old 05-13-2016, 08:33 PM
nikhilmulay nikhilmulay is offline
Thumbs up for Paragon. I've been using it to read mac formatted drives on my pc for a long time now. Flawless and completely transparent. It just shows up as a regular drive on your machine.
I've been assembling and running protools on pc since version 7 and have yet to encounter a major hiccup. Read up on the i7 thread and you should be good.
Sent from my SM-G900F using Tapatalk
Old 05-18-2016, 02:46 PM
Thanks to all who responded.
I will check out the i7 thread.
And other software suggested.
TWM
PS Yikes over 600 pages to that thread!
That is a bit overwhelming!
Looking more and more like I may join the mass migration to Studio One.
Old 05-19-2016, 08:17 AM
The Weed's Avatar
Just look at the first page, new systems are posted there, then ask questions in the thread.
SonoBus
Old 05-19-2016, 02:31 PM
Neil H Neil H is offline
Thanks The Weed and Bob for recommending us, our aim is certainly to provide systems that just work and to take away the gamble and guesswork a self build can pose not just in component selection but configuration too.
We urge our customers to lean on us for help whenever required so you wont ever be alone if you come up against a problem.
I certainly agree with the suggestion of Paragon HFS for Windows as previously mentioned its totally transparent and i've never come across any problems with it since I started using it which is more than I can say from years of use with Mediafour Macdrive.
You wont even need to copy stuff over just run the sessions straight from your Mac formatted drives.
Pro Tools 2019.5 Ultimate
Windows 10 Pro
Join the Facebook Pro Tools Windows User Group
Thinking of moving to Pro Tools. I have Questions.. TheEdster75 Windows 5 04-17-2012 10:06 PM
Thinking of moving to iMac, help please! paulrgmusic macOS 19 08-17-2011 03:44 AM
Windows Thinking of moving over to Mac Pro Loyd981 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-03-2010 01:30 PM
Thinking of moving from Xp to Vista Flpalla Pro Tools M-Powered (Win) 1 10-11-2008 11:23 AM
Some advise needed rara114 Pro Tools TDM Systems (Mac) 5 05-26-2007 07:20 AM
