  #21
Old 02-28-2018, 05:17 PM
PatriotsBiker PatriotsBiker is offline
Default Re: Pro Tools 2018.1 low latency monitoring issues
Have any of you tried doing the Apollo hardware re-set procedure?
  #22
Old 03-05-2018, 08:58 AM
michaelevancoe michaelevancoe is offline
Anyone found a solution yet? LLM still completely broke
  #23
Old 03-06-2018, 04:57 AM
Oufti Oufti is offline
Just tried that, doesn't help (good idea though)
  #24
Old 03-06-2018, 10:16 PM
chrisatkinsonline chrisatkinsonline is offline
This issue is killing me!! Please Avid fix this!!
  #25
Old 03-07-2018, 01:00 AM
Have we all contacted Avid support?
I’m not making much progress with them but if we all contact them about this maybe they’ll take it more seriously.
  #26
Old 03-08-2018, 12:29 AM
You are right, I do that today
  #27
Old 03-08-2018, 01:25 PM
greyskull greyskull is offline
Jas, I've had some issues (signal from PT and from Apollo playing at the same time) when using the Green I for selective track monitoring as opposed to the global alt+k. Toggling it off and on with selective monitoring seems to fix it... sometimes.
Definitely pretty janky at the moment. I've only just started using LLM for Unison plugs.
  #28
Old 03-08-2018, 06:02 PM
Just tested on 2018.3, no luck
  #29
Old 03-09-2018, 12:10 AM
- THIS WORKED FOR ME -
Contacted Avid yesterday, got an answer today:
There are two things can try for now to see if it cures the issue:
- A power cycle: turn the Apollo 8p off and disconnect for around 5 minutes and turn it on again.
- Reset your preferences:
Reset / Trash Preferences
- Hold 'alt' and click on Go (Menu Bar)
- Go to [Library]
- Go to [Preferences]
- Go to [Avid]
- Delete the [Pro Tools] folder, then empty trash.
Reset / Trash the Workspace
- Open Finder
- Go to [Macintosh HD] / your main hard drive
- Go to [Users]
- Go to [Shared]
In a previous post I said that it didn't work... my bad! Actually deleting the prefs UNCHECKED the LLM by default, so when I opened my session I had a double signal even in stop mode (on the record armed track). Sorry for being so stupid ;-/
Thanks John!
  #30
Old 03-09-2018, 01:45 AM
Awesome! will try this when i get to work!
low latency monitoring in Pro Tools 11 - IS THERE AN ANSWER ....? Zee&Eli Pro Tools 11 22 03-10-2017 07:23 AM
Low Latency Monitoring in Standard Pro Tools 9? Dizzi45Z Pro Tools 9 20 02-06-2012 08:55 PM
Pro Tools 9.0.5 - Low Latency Monitoring problem still persists xazqe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-02-2011 08:54 AM
Monitoring Latency issues 001 and Pro-Tools 6.4 LE eastwood1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 21 08-30-2006 01:04 AM
Pro Tools Free OS 9 monitoring latency - help!! sunlikeblood Digidesign Hardware & Software 2 12-29-2003 04:56 PM
