Old 10-14-2019, 07:42 PM
fsavell fsavell is offline
Default PT 2019.6 not clearing memory
Currently looking at my System Usage window with no sessions open and the memory bar shows 81% memory usage (Activity monitor confirms 32GB out of 48GB are used).
Why is PT hanging on to this memory usage? Disk Cache is only 10GB.
Only noticed it because PT was taking forever to delete tracks (much slower than closing a session).
Restarting PT obviously fixes it. Anyone else seen their memory usage high after closing a session?
Forrester
Pro Tools Ultimate 2023.12, HDX1 • Mac Studio M2 Ultra - macOS 14.2
Old 10-14-2019, 08:31 PM
Default Re: PT 2019.6 not clearing memory
Could be a classic sign of a plugin memory leak (which can happen with no session open).
How much of the disk cache is actually used? How large are your sessions? How many/what VIs -- the classic memory pig plugins, but if it's a leak any of them can cause that.
Does this happen only with one session?
Check all your plugins are up to date, as always start with trashing prefs did that fix it? If not try removing all .aaxplugin files from your plugins folder and trash prefs again and restart and just play around with only the default plugins (that get put back magically by Pro Tools) installed. Add others back in batches to see if you can find which one is causing the problem.
You also need to be a bit careful with looking at memory stats, things don't always work how they might seem. e.g. The amount of apparent free system memory can to run low in a healthy system, its the virtual memory system just not being bothered to spend effort freeing pages (which if read from disk *are* the systems disk cache for programs and data) or flushing stuff back to disk if it does not need to. Often low-level tools give more insight than the simple meters.
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 08:30 AM
CPU errors during playback resolved by clearing up memory. ramonetl Pro Tools 12 19 04-10-2016 08:49 PM
PT10.3.3 - Win7 - 9172 - Clearing Memory Cache flawlessempire Windows 0 03-06-2013 07:28 PM
PT 8 Not Clearing DSP liquidghost Pro Tools TDM Systems (Win) 18 01-13-2010 02:12 PM
