Old 06-14-2018, 06:44 AM
reichman's Avatar
reichman reichman is offline
Default Video Format: Encoded Size vs. Display Size?
I have a video from a client:
DNxHD
bit rate 100 Mbit/s
interlaced
encoded size 1440 x 1080
display size 1920 x 1080
It doesn't perform well. A little choppy, AVE reads 160% CPU usage. Converted the video with Media Encoder to one of my DNx presets to this:
DNxHD
bit rate 147 Mbit/s
progressive
encoded size 1920 x 1080
And now AVE is using 80% CPU. I've run into this "encoded size" issue before. What's happening? Or is it the interlacing that's causing the AVE problem?
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 06-14-2018, 12:36 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
Default Re: Video Format: Encoded Size vs. Display Size?
To my simplistic understanding the issue is the scaling required to display the pixels correctly.
The 1920 by 1080 has a 1 to 1 pixel sizing - no display scaling.
The 1440 by 1080 has a 1 to 1.2x pixel sizing -intense display processing.
Andrew
Old 06-15-2018, 01:20 AM
papalou papalou is offline
Andrew
You're 100% right, except for the pixel aspect ratio, which is 1.33 and not 1.2.
Old 06-15-2018, 08:08 AM
reichman's Avatar
After some more testing, I found that I could run AVE all day at 40% CPU usage by going 1280 x 720p. For most programs, that looks good enough in a medium-sized post room. Size matters, scaling matters. Not sure about interlacing. I'll save that test for next time.
Nathaniel Reichman
Dubway Studios
Old 06-20-2018, 03:33 AM
MatzeHD MatzeHD is offline
1440 * 1080 is anamorphic HD from HDV, DVCProHD Format etc., its older and only sometimes used today. It was for a better backward compatibility to SD 16:9 anamorphic.
Yes, you must only change the 1440 to 1920 picel output on the new encoding and all is fine!
Old 06-20-2018, 03:52 AM
DNxHD
bit rate 100 Mbit/s
interlaced
DNxHD
bit rate 147 Mbit/s
progressive
Sound like you are transcoding to an extreme DNxHD bitrate. Try DNxHD36. (1920x1080 @ 36Mbit/s) very light CPU usage and looks just fine for sound work.
Unless you are projecting super-big 36 is plenty for sound work.
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Old 06-24-2018, 06:45 PM
Ayush Ahuja Ayush Ahuja is offline
+1 on Frank's suggestion.
DNxHD36 works perfectly fine and is often what picture post use for their offline cut if using Media Composer. On the current job I just get a same as source output.
Ayush
PTHD Ultimate 2019.6, MacMini 2.3GHz i7 16GB RAM OSX 10.12.8, Mbox Pro (3rd Gen) + VideoSlave 3.4, MacMini 2.5GHz i5 8GB RAM OSX 10.12.8
HTML code is On
S3 Display font size problem hj0102 Pro Tools | S3 17 01-07-2019 10:22 AM
How to increase track display size? HaydenF Pro Tools 12 4 04-08-2016 03:25 PM
Format Staff Size swingaroux Avid Scorch (iOS) Forum 4 08-04-2015 09:10 PM
Increasing display font size MboxToo Tips & Tricks 1 05-06-2009 06:17 PM
Which Size Apple Display Does PT Look Best On? decibel Pro Tools TDM Systems (Mac) 23 12-17-2003 06:54 PM
