Old 07-02-2013, 12:25 PM
BondAudio BondAudio is offline
Default MBox Pro (3rd generation) and Surround Monitoring.
Hello,
Is anyone out there using the latest generation MBox Pro for surround mixing and monitoring?
Manual, page 31:
You can choose which Monitor output pairs are controlled by Mbox Pro’s Master Volume knob.
For example, if you enable Master Volume for all three Monitor output pairs, then the Master Volume controls all of them at once. This is useful if you are mixing in surround
My goal is not to purchase a surround monitor controller.
Many thanks in advance
Old 07-02-2013, 09:16 PM
Ayush Ahuja Ayush Ahuja is offline
Default Re: MBox Pro (3rd generation) and Surround Monitoring.
Its pretty easy to setup -
In the mbox pro app - setup > output setup tab:
Tick the Master volume box for all three output pairs. The front panel knob will now control the volume on all 6 outputs.
I use this as my surround monitor setup and controller, works fine.
Yush
Old 07-03-2013, 02:39 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Yeah, same here. The only disadvantage is a lack of alternate outputs at +4dbu for metering. The output level of MBP 3 is a a way lower than standard line level ( e.g. Avid HD IO) even at the maximum volume position.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2019.6 Ultimate ● macOS High Sierra 10.13.4
MacPro 2 x 2.4 GHz Quad-Core Intel Xeon ● 24 GB RAM
Avid HD I/O ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
HTML code is On
Mbox Pro 3rd Generation. Pacificfrost FireWire and USB Audio Interfaces (Mac) 3 07-29-2013 11:53 PM
Mbox 3rg Generation renando316 Pro Tools 9 4 06-16-2011 01:51 PM
Mbox 1st generation and OS 10.5.7 caz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-24-2011 04:04 PM
Surround Monitoring splicestudios Post - Surround - Video 3 04-12-2005 06:55 AM
Surround encoders for new generation of software? Mark Wheaton Pro Tools TDM Systems (Mac) 8 05-09-2004 03:54 PM
