Old 01-15-2007, 03:55 PM
BlindDog BlindDog is offline
Default Memory Leak in 7.3?
This is an issue I've finally been able to recreate. It may be PT's plugin management but it is happening. I am on Windows XP Pro, a Dell machine recommended by Digidesign, and this never happened prior to 7.3. The following is a basic example:
1. I open three or four projects in a row, doing a little work on each of them before closing.
2. At some point, PT starts acting EXTREMELY slow, like it will hang. Typical project would be 6 - 10 tracks, with 3 - 4 tracks having one plugin and maybe 1 or 2 plugins on a AUX or Master Fader track. Once I reach this point, if I even press Play in PT, nothing happens.
3. I check the Task Manager in Windows and watch memory consumption steadily climbing, up to 850,000k and up. If I wait long enough, assuming I pressed Play in Step 2, it will play, but then even hitting Stop will take start the eternal wait.
4. Now I close PT and reboot my computer. I bring up the last tune that was acting up. With absolutely no changes, everything is lightning fast and memory consumption in Task Manager is 600,000k or less, and not climbing.
I have been able to do this repeatedly. I am rebooting constantly. And as I said, this is all entirely new. I was just wondering if anyone here has any ideas before I submit this to PT support.
Thanks.
Old 01-15-2007, 06:26 PM
spkguitar's Avatar
Default Re: Memory Leak in 7.3?
What plugins do you have installed? Are they all PT7 compatible? Even having one non-compatible plugin installed, even if you aren't using it in the session, can cause problems.
That would be the first thing I would check for if it was me.
Old 01-15-2007, 08:21 PM
The plugins are compatible--that was the first thing I checked.
Memory leak going 11.01>10.3.6 DetroitT Pro Tools 11 0 07-18-2013 03:42 AM
Memory leak in PT7cs3? UnkleMik Pro Tools TDM Systems (Win) 1 02-03-2006 12:53 AM
PT6.9 MEMORY LEAK!!!!!! COME ON DIGI :( de_mix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 08-22-2005 02:36 PM
Protools Memory Leak???!!! Agentemo1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-08-2005 05:39 PM
Memory leak fixed yet? Ever? RobbaDobba Pro Tools TDM Systems (Mac) 9 01-29-2001 07:04 AM
