Old 05-09-2012, 07:45 PM
pie55 pie55 is offline
Default sandra report
I bought an accel card that isn't working in my set up. Are there any other tests except digitest to verify that the card is in deed faulty?
I don't want to ship it back unless Im sure it's broken.
WIth the accel card installed I get error 4 then 9003 when loading Pro tools. Digi test won't even start with the accel. I tried swapping the core card with the accel. same error. I uninstalled accel card and digi test works fine with core card.
ANy help is greatly appreciated
Follows is my sandra report.
SiSoftware Sandra
ID
Host Name : ae-c11b10cc6eb1
Workgroup : WORKGROUP
Computer
Model : OEM System Product Name
Serial Number : System Serial Number
Chassis : Chassis Manufacture Tower
Mainboard : ASUS K8N-DL
Serial Number : 123456789000
BIOS : Phoenix Technologies, LTD ASUS K8N-DL ACPI BIOS Revision 1008 02/17/2006
NUMA Support : 2 Unit(s)
Total Memory : 2.5GB ECC DDR Registered
Processors
Processor : Dual Core AMD Opteron(tm) Processor 265 (2C 1.81GHz, 1.81GHz IMC, 2x 1MB L2)
Chipset
Memory Controller : ASUS nForce4 Memory Controller 2x 1GHz (2GHz) FSB
Memory Controller : AMD Athlon 64/Opteron HT Hub 2x 1GHz (2GHz) FSB, 2x 1GB ECC DDR Registered 2x 201MHz (402MHz)
Memory Controller : AMD Athlon 64/Opteron HT Hub 2x 1GHz (2GHz) FSB, 512MB ECC DDR Registered 2x 201MHz (402MHz)
Memory Module(s)
Memory Module : OCZ OCZ400512SSER 512MB ECC DDR Registered PC1-3200R DDR1-400 (3-3-3-8 2-11-0-0)
Memory Module : Kingston 512MB ECC DDR Registered PC1-3200R DDR1-400 (3-3-3-8 2-11-0-0)
Video System
Video Adapter : NVIDIA GeForce 8400 GS (8 SP 1.35GHz, 512MB DDR2 798MHz 64-bit, PCIe 1.00 x16)
Graphics Processor
Storage Devices
Maxtor 6Y120P0 (123GB, ATA133, 8MB Cache) : 114GB (C:) (D:)
WDC WD10EARS-00Y5B1 (1TB, USB2/SATA300, 3.5") : 932GB (H:)
HL-DT-STDVD-RAM GH22NP20 (8.5GB, ATA66, DVD+-RW, CD-RW, 2MB Cache) : 8GB (E:)
Logical Storage Devices
Partition 1 (C:) : 57GB (NTFS) @ Maxtor 6Y120P0 (123GB, ATA133, 8MB Cache)
Partition 2 (D:) : 57GB (NTFS) @ Maxtor 6Y120P0 (123GB, ATA133, 8MB Cache)
Pro Tools HD (E:) : 8GB (CDFS) @ HL-DT-STDVD-RAM GH22NP20 (8.5GB, ATA66, DVD+-RW, CD-RW, 2MB Cache)
Floppy Disk (A:) : N/A
New Volume (H:) : 932GB (NTFS) @ WDC WD10EARS-00Y5B1 (1TB, USB2/SATA300, 3.5")
Peripherals
LPC Hub Controller 1 : ASUS nForce4 ISA Bridge
LPC Legacy Controller 1 : Winbond W83627THF/THG
Audio Device : ASUS nForce4 AC'97 Audio Controller
Audio Codec : Realtek Semi 0090h
Audio Device : AVID Tech 56361 Audio I/O Controller (MIDI)
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : ASUS nForce4 Memory Controller
Disk Controller : ASUS nForce4 Parallel ATA Controller
Disk Controller : ASUS nForce4 Serial ATA Controller
Disk Controller : ASUS SiI 3114 SoftRaid 5 Controller (ASUS 8136)
USB Controller 1 : ASUS nForce4 USB Controller
USB Controller 2 : ASUS nForce4 USB 2.0 Controller
FireWire/1394 Controller 1 : ASUS TSB43AB22 1394a-2000 OHCI PHY/Link-Layer Controller
SMBus/i2c Controller 1 : nVidia MCP2 SMBus 1
SMBus/i2c Controller 2 : nVidia MCP2 SMBus 2
Network Services
Network Adapter : Broadcom NetXtreme Gigabit Ethernet - Packet Scheduler Miniport (Ethernet)
Network Adapter : Belkin F5D8053 N Wireless USB Adapter #2 - Packet Scheduler Miniport (Ethernet, 72Mbps)
Operating System
Windows System : Microsoft Windows XP Professional 5.01.2600 (Service Pack 2)
Platform Compliance : x86
Old 05-10-2012, 04:47 AM
lennieh lennieh is offline
Default Re: sandra report
have you got the ribbon installed correctly, it's quite easy to connect this up wrong when you start swapping the card order....
Old 05-10-2012, 08:48 AM
the ribbon is pluged into b of the core card and a of the accel
Old 05-10-2012, 04:30 PM
can any one see an issue in my sandra report? I should also note that my system worked well with a Process card. Unfortinitly I sold the process card to fund my accel purchase.
WHat I really don't want to happen is to buy another accel and get the same error.
Thanks
sandra report vin7 Windows 3 03-26-2014 03:47 PM
Sandra report mickeyrouse Getting Started 3 01-13-2014 05:57 PM
Sandra Report keithaska 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-23-2010 12:43 PM
Thanks! Sandra Report stevegrisham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-08-2009 09:26 AM
Sandra Report Help Please JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-09-2007 05:52 AM
