Old 02-12-2022, 04:12 AM
ian1866 ian1866 is offline
Default Protools 9 - 192 connection
Mac has been replaced - protools 9.0.6 installed and working - HD core passes test.
Setup - hardware - no interface listed - in aggergate I/O
There is a PCI tab saying “Digidesign HW (HD)” with 0/0
Can’t get the 192 (updated to 4.9 firmware from within the digitest) connected
What can I try next.
Old 02-12-2022, 02:53 PM
Default Re: Protools 9 - 192 connection
Hmmm, what cards are installed? Can you test with only the CORE card(if you have HD2, 3, etc). Does your iLok show the PT9 HD license? Is this a new setup for you or a rebuild with previously working hardware? What is different on the new computer as compared to the old(same OS?)?
Old 02-13-2022, 01:43 AM
Hi Dave
Thats interesting - are you saying on the Ilok I should have 2 Licenses. 1 for Protools and 1 for the HD cards - Its HD2 with 1 Accel Core and 1 Accel card - they both pass Digitest as do the interfaces which I can see change when I disconnect them.
The System was a Mac 4.1 which developed a processor fault - I never looked at the Ilok key just used it. It was built in a rack and not easily accessible. The Ilok key got snapped of when the machine went to repair and thrown away - as it was thought to be a USB.
I have it replaced with a Mac 5.1 and Avid have recovered the Protools license, and it is on a new Ilok on its own, and protools works fine, but wont load any interfaces.
Is this because the Card Licenses are missing and where do I get them??
Thanks
Ian
Old 02-13-2022, 09:15 AM
Hey Ian, no, its just a single license for Pro Tools 9 HD. Since you had everything working on a previous machine, the iLok license should be fine, BUT(a great big "BUT") was the old iLok one of the first gen style(green key-shaped) and the replacement one of the newer gen 2 or 3 iLoks? First thing to do is to open iLok manager and see if the iLok shows up AND shows the 9 HD license. My thinking is that maybe a new iLok won't read correctly on your older machine and OSX version.
#2(assuming ILM shows the iLok and license)-I'm not sure if it matters what slots get used, but I would probably try removing the Accel card and test the 192 with only the core card. If that works, then maybe suspect the ribbon connector?
Old 02-13-2022, 09:18 AM
BTW, another test for the license question would be to try running Pro Tools on the core audio instead of the HD card/192. If PT opens and runs that way, then you know licensing is good.
[IMG] code is Off
Outboard connection to protools kratos21 General Discussion 6 08-19-2021 03:38 AM
Protools 2019 asking for internet connection teacherman Pro Tools 2019 3 08-20-2019 03:58 PM
C|24 connection issue with Protools HD12 Noyan ICON & C|24 16 09-02-2016 10:39 PM
ProTools to Masterlink Connection? Digitalkidd Pro Tools TDM Systems (Mac) 2 05-29-2005 02:02 PM
Connection Avid and Protools SpyAJ15 General Discussion 2 06-28-2004 08:54 PM
