Old 07-04-2017, 07:38 AM
WilliamSumnerMusic WilliamSumnerMusic is offline
Default All of a sudden crossfades wont work
I have been using Pro Tools 9 for a few years now with out any problems but all of a sudden crossfades wont work anymore and I havent changed the way ive recorded or set anything up. When i try to crossfade i get a message reading "one or more fade requests are invalid due to insufficient audio data within the fade bounds. You may skip the invalid fade requests, or adjust the bounds for those fades (where possible). I have tried selecting both skip fades and adjust bounds without the results im used to. Every solution i have read about dont seem to work. I have tried everything i know and am at a loss of what to do. Any help would be greatly appreciated. Thanks!
Old 07-04-2017, 09:12 AM
Default Re: All of a sudden crossfades wont work
2 possibilities:
1-the audio you are trying to fade has nothing past its visible edge. How do you know if there is nothing past the edge? Use the trim tool and try to drag the clip edge(to make the clip longer). If you get nothing, then there's nothing to crossfade(it took me a while to get my head around this, so don't feel bad if you have to think about it a bit)
2-trashing prefs is worth trying for any "odd behavior"
Old 07-04-2017, 11:36 AM
YYR123's Avatar
YYR123 YYR123 is offline
Yes trashing prefs sounds like a winner.....
https://www.sweetwater.com/sweetcare...s-preferences/
Daniel
Old 07-05-2017, 12:04 PM
YYR123's Avatar
MODS this probably should be moved to the PT9 discussion.
Daniel
Old 07-05-2017, 06:16 PM
Trashing the Preferences is exactly what needed to happen, thanks for the help and information guys.
Old 08-12-2017, 01:56 PM
TNM TNM is offline
Going nuts here with this. I always thought it was a big but nothing changed n 12.8
Trashing prefs didn't help.
It just keeps resizing my crossfade to the "correct" bounds. Never seen anything quite like it! I have two audio clips overlapping and i can't do more than a 1 bar crossfade! How does that work? I've turned snap off and checked every single forum and video i can find on this and nothing helps...
I have no idea.. would love some help...
is this a vanilla limitation? Apparently HD has better crossfades?
Edit, my brain finally clicked and I worked it out.. Pro tools, unlike other DAW's, does NOT allow you to do a longer crossfade than the exact length of the overlapping portion of the clips. That's the "boundary".
See in Logic or Cubase I could have one file fading out before the actual other one started to come in at all, i could do whatever length X fades i wanted wherever i wanted.
Chalk a win for that one to Logic then. The only other alternative is to use 2 audio tracks and a regular fade on each.
Still, PT is awesome.
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX
Old 08-12-2017, 05:22 PM
The Weed's Avatar
The Weed The Weed is offline
Changing your handle length may help. However, if there is no audio, there is nothing to fade into or out of.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-12-2017, 07:55 PM
TNM TNM is offline
no but with other DAW's i can have the crossfade as part of the fade and fade out the first audio as part of the crossfade, before i am fading the overlapping bit. I am sure I am probably explaining it wrong, but there's definitely audio there. It's ok, in PT i can just draw a normal fade on top if i want the left (original) audio to start fading before the crossfade hits.. i think.. will check that out today.
Old 01-02-2022, 07:13 AM
xlrashn35 xlrashn35 is offline
Having the same issue in 2021.10 and up .. I have 2 clips with audio, slip mode, crossfade size less than a bar, less then a beat in actuality, and getting this same error. does the fade out on the left clip and a fade in on the right clip behave the exact same as a cross fade? Newbie in production, sorry for the dumb question.
Old 01-02-2022, 08:32 AM
Posting in this old thread is not likely to get you any good advice. Go to the section for the current version of Pro Tools and post there. Re-read the advice above and see if that helps, or is the cause.
[IMG] code is Off
003 wont work! trav._ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-24-2009 09:21 PM
strike wont work robowisa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-02-2007 04:17 PM
Pro Tools WONT LAUNCH! - All of a sudden !?! gollywillickers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-14-2006 05:55 AM
All of a sudden mp3 option doesn't work... stevegalante Pro Tools TDM Systems (Mac) 2 09-02-2005 11:48 AM
MP3 option wont work please help Gilley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-07-2005 02:16 PM
