Old 09-14-2019, 11:46 PM
TrentWilliams TrentWilliams is offline
Default Production FX, Foley, .. etc
Hey all,
I have a small question regarding your personal workflow,
What do you all do with pfx / production sound outside of the dialog itself when working on a project? Do you keep it in the dialog group, or cut it into its own group and send it to the same denoiser chains as the take it came from?
Looking for tips, and/or workflow advice,
Cheers
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 09-15-2019, 12:46 AM
Led Led is offline
Default Re: Production FX, Foley, .. etc
I cut them out to their own track when doing dx cleanup. PFX track is part of my template I use. That gets grouped with my other sfx and sent to the sfx bus. If they are noisy I'll do some nr but on the pfx track and automate it using preview/write to . I don't usually find pfx need as much nr as dialogue because they aren't as upfront. Normally need to fill the dx track where you pull them out from though unless there's a music track covering the gap or the dialogue was really clean the begin with. It also depends on a bunch of things like how good they sound, if they are crossing dialogue, it there is time/budget to replace them all (haha yeah right!) but most of the time i'm doing as above, or layering stuff on them using them as a base, which I prefer, if there's time/budget (haha....)
Old 09-15-2019, 07:35 AM
paulo m's Avatar
paulo m paulo m is offline
I keep it on the same dialog busses, on separate tracks, unless it´s supposed to be all replaced.
I usually clean up the production dialogue on RX, then send the clean takes to separate tracks from the pfx and ambient that remains. I also clean the pfx that I intend to use, so that it blends well with the pdx. I don´t like to use dialogue noise reduction in real time, so I avoided it, if time allows.
I usually also blend some other fx on top of the pfx or even ambient sounds.
It all depends on the time I have for a given project and the source material.
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
HTML code is On
Using samplers for Foley reichman Post - Surround - Video 7 05-19-2014 05:53 AM
Foley microphones sonicam Post - Surround - Video 13 01-13-2006 01:59 AM
foley recording PRATHAP Post - Surround - Video 3 09-15-2005 03:57 PM
ADR FOLEY STUDIO 44 Pro Tools TDM Systems (Mac) 8 02-01-2005 02:46 PM
6.4 Foley... K-Man Pro Tools TDM Systems (Mac) 0 08-17-2004 07:54 AM
