Old 08-30-2010, 12:32 PM
dopplah dopplah is offline
Default Pro Tools -> Final Cut -> Pro Tools
I need to pass a Pro Tools session to a FCP editor, get his tweaks and get the session back for final mix. Evidently he needs Automatic Duck to import the OMF? Is Final Cut 7 unable to import OMF without this add-on?
Also, would you recommend aligning my audio so all sounds start and end on even frames? I'm told that FCP will auto-generate head and tail files for anything that is in between frame borders. Either he or I would need to delete these sounds later on and "pull out" the heads & tails of the original sounds.
Not to mention we'll encounter the 23.976 FPS / 24 FPS confusion going either direction via OMF? Won't FCP think my 23.976 session is 24?
Shawn
HTML code is On
Final Cut EDL to Pro tools Help Bantom Post - Surround - Video 2 07-31-2013 09:28 PM
Pro Tools and Final Cut mastroiani Post - Surround - Video 6 03-17-2010 01:01 PM
conflict with pro tools and final cut pro Mlanders Pro Tools TDM Systems (Mac) 6 01-12-2006 06:33 PM
Pro Tools 4.5 with QuickTime 7.03 and Final Cut dannio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-09-2006 08:00 AM
Pro Tools LE and Final Cut on same Computer KarlAtteln 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-11-2004 07:22 AM
