Old 11-18-2011, 04:16 AM
jacko's Avatar
jacko jacko is offline
Default Pro Tools 10 HD Native - what OS for firmware upgrade?
I read about problems with upgrading HD Native firmware. I was going to install Pro Tools 10 HD on Mac OSX Lion. Should I install 10.6.7 first to upgrade the firmware?
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
Old 11-18-2011, 10:03 AM
drumster drumster is offline
Default Re: Pro Tools 10 HD Native - what OS for firmware upgrade?
Yes. You are only asking for problems if you do it any other way. Save yourself the time and headache and upgrade the firmware using 10.6.7.
Lynx Hilo Thunderbolt
2013 Retina Macbook Pro 2.7 16 GB of RAM
PTHD 11.3.1 OSX 10.10.1
Old 11-19-2011, 08:07 AM
kazuomik kazuomik is offline
In order to update the firmware of HD Native card to v1.03 on Mac OS X, the version of Mac OS X must be 10.6.7 or earlier, and it requires Pro Tools HD 10 or 9.0.5.
However, Pro Tools HD 10 runs on Mac OS X 10.6.7 or later, so 10.6.7 is the only choice to update the firmware of HD Native card to v1.03 with Pro Tools HD 10.
If using Pro Tools HD 9.0.5, it runs on any version of 10.6.x and 10.7.x, so you can update the firmware to v1.03 with Pro Tools HD 9.0.5 on Mac OS X 10.6.7 or earlier.
I did it last weekend, prepared the disk partition for Mac OS X 10.6, installed Mac OS X 10.6 to new partition, upgraded it to 10.6.5 (this might not be necessary), installed Pro Tools HD 9.0.2, and upgraded it to 9.0.5 just for the firmware update to v1.03. Now, Pro Tools HD 10 is running on Mac OS X Lion 10.7.2 very well.
Old 11-19-2011, 01:28 PM
jacko's Avatar
I'm on 10.6.8 at the moment. If I run 10.6.7 Combo Update will it downgrade my system?
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Old 11-19-2011, 03:38 PM
jacko's Avatar
If someone runs Lion and they don't have access to 10.6 - what can they do?
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Old 11-19-2011, 04:34 PM
I don't think so.
I think you can contact to Avid, and Avid will update the firmware for you as follows:
http://avid.custkb.com/avid/app/self...p?DocId=419331
Suggested Resolutions:
· Upgrade to Pro Tools 9.0.5 using a non-Thunderbolt MacBook Pro and OS 10.6.7* or lower.
* With a MacBook Pro: MacOS X 10.6.7 (10j3331a) works; MacOS X 10.6.7 (10j4139) does not work.
· Alter HD Native card slot order arrangement
· Attempt the update numerous times in a row by re-launching Pro Tools.
· Contact Avid Audio Technical Support on the repair line: http://www.avid.com/US/support/support-contact
Old 11-20-2011, 03:23 AM
thegreyfox thegreyfox is offline
yes it will. I did this the other day.
Old 11-26-2011, 07:19 PM
meech meech is offline
The safest thing is to create a new partition and install 10.6.7 there for the firmware update.
Old 11-29-2011, 01:34 PM
Buccanears's Avatar
Buccanears Buccanears is offline
I've just built a Westmere 12 core with 10.7.2 and as long as the HD Native card is in slot 4, firmware seems to upgrade as per normal. Testing now, but looks as though it's hunky dory. Slot 2 no workies...
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 12-07-2011, 09:24 PM
thope thope is offline
i've just encountered the same issue. Just installed PT 10. When i launch PT it tries to update the firmware on the Native card and then freezes. I'm on 10.6.8. I've tried to go back down to 10.6.7. but cant seem to do it. I've created a partition like suggested but when i run the 10.6.7 combo update it doesn't let me select any of the drives. I tried booting of the 10.6 DVD and it just said that it couldnt install this software on this computer.
Any suggestions
Native card Firmware upgrade. Is it backward compatible? brickroadstudio Pro Tools HDX & HD Native Systems (Mac) 0 11-24-2013 11:44 AM
Pro Tools 10 Native to Pro Tools 10 HD upgrade aldersyde Pro Tools 10 3 11-01-2013 11:54 AM
Downgrade Native firmware 10 to 9? Hugh-H Pro Tools HDX & HD Native Systems (Mac) 2 04-12-2013 09:53 AM
Hardware upgrade to HD Native / Pro Tools 10 SZE Pro Tools 10 2 04-10-2013 05:27 PM
HD Native Firmware Flash TimNielsen macOS 5 01-29-2012 01:59 PM
