Old 04-23-2004, 09:55 AM
locosoundman locosoundman is offline
Default digital ins SPDIF and ADAT simultaneous
If I were attempting to record with the ADAT and SPDIF ins at the same time, and the devices could not use clock to sync externally, how would I set the 002r to receive clock - SPDIF or ADAT? Would this even work? Last but not least, recording 8 ch on ADAT, set clock to ADAT - will I be able to use all 8 analog ins without artifacts? Has anyone done used all 18 ins successfully?
My PC does 32 + 8 on the DaveC test and 23 dverbs, so I don't think processing power will be an issue if I ever have to attempt this.
Newbie - please be gentle...
What does this little red button do?
Old 04-23-2004, 04:58 PM
Default Re: digital ins SPDIF and ADAT simultaneous
I answered this in your other thread. Both devices must share a common Word Clock.. and Pro Tools must be externally clocked to the master clocking device.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 04-25-2004, 06:08 PM
s.d. finley s.d. finley is offline
RJR is correct.... i use both spdif and adat on my 001 everyday...DA7 into adat, focusrite VMP into spdif, both are clocked to a Lucid Genx6 with NO problems. I can record to all 18 inputs on the 001 all at once. I have the 001 clocked to the spdif inputbecause my spdif cable is short.
rock
sdf
sdf
www.sugarhillstudios713.com
Simultaneous AES/ADAT/SPDIF on HD I/O Digital crazyhorse Pro Tools HDX & HD Native Systems (Mac) 5 11-18-2018 08:18 AM
003 ADAT Optical & SPDIF inputs - simultaneous recording? ciacco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 19 03-28-2007 07:49 PM
Digital mixer pre's or 002R? SPDIF or ADAT I/O? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-14-2006 08:24 PM
possible simultaneous ADAT with 192 & 192 digital? Judson Pro Tools TDM Systems (Mac) 1 07-03-2004 02:41 PM
ADAT to 4 SPDIF i/o's & digital inserts polchik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-18-2003 01:53 PM
