Old 04-15-2014, 07:19 PM
ericgreedy ericgreedy is offline
Default AAE -9173 errors, MacBook Pro 15 inch, Mid 2012, PT11.1.2, New SSD's and RAM
Hello ,
Macbook Pro, HD11, Universal Audio setup (full specs below).
Problem: AAE -9173 errors
I after switching to SSD's and doubling my RAM from 8 to 16GB last week, I have been getting AAE -9173 errors. This new RAM passed a memtest. for the SSD's Trim Support is enabled.
Even in sessions that use only about 20-50% of my UA resources, and the average total CPU on the Pro Tools System Usage meters (disk 1%. memory 15%).
Regarding the most recent error:
Session format: 24bit/44.1Khz, BWAV
Less than 20 mono audio tracks, a half dozen stereo tracks, dozen mixed mono, stereo auxes. Very small. I would generally have few if any issues on a session this small before I increased RAM and switched to SSD's.
I hope someone has some insight … I would love a (more) stable rig.
Suggestions?
My system:
* Processor: 2.6 GHz Intel Core i7
* Memory: 16 GB 1600 MHz DDR3 {purchased recently, passed metest twice]
* Software: OS X 10.8.5 (12F45)
* Internal Drive 1 (system drive): Samsung SSD 840 EVO 1TB
* Internal Drive 2 (optical bay, record drive): Samsung SSD 840 EVO 250GB
* Trim Support: Yes
DAW:
* Pro Tools HD11.1.2
* Playback Engine: Universal Audio Apollo
* H/W Buffer Size: 1024 Samples
* Host Engine Ignores Errors during Playback/Record: OFF
* Dynamic Plug-in Procession: OFF
* Video Engine Enable: OFF
Interface:
* Universal Audio Apollo Quad, Thunderbolt Card
* Software: UAD Powered Plugins 7.5.0 02-14-2014 build 6455
Expansion Chassis:
* Magma ExpressBox 3T, Thunderbolt to PCIe
* UA Quad PCIe card
* UA Octo PCIe card
Old 04-15-2014, 08:16 PM
Cutlerbri Cutlerbri is offline
Default Re: AAE -9173 errors, MacBook Pro 15 inch, Mid 2012, PT11.1.2, New SSD's and RAM
Am I seeing this right, Eric? Do you not have an external drive (hard drive or SSD)?
Brian
See profile page for system details
Old 04-15-2014, 08:20 PM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
2 internal SSD's I saw...
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Old 04-15-2014, 08:24 PM
Southsidemusic's Avatar
And that should be Plenty of power for this computer
No need for external drives as thats the same as 2 separate SSD drives
Best
Christopher
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-15-2014, 08:28 PM
Got it, Chris. Thanks.
Brian
Old 04-15-2014, 08:33 PM
Bruce?!! …. Help? !!!
Old 04-16-2014, 05:57 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
I'm not a tech, just the forum admin, but here's what I would try.
Is there any way you can try a different recording drive, adding an external drive some way (to eliminate the possibility that the SSD connected via optical drive bay is a factor)?
Bruce Paine
System Details
Old 04-16-2014, 09:55 PM
JFreak's Avatar
JFreak JFreak is online now
Apple also officially only supports 8GB memory for this model. I Don't think it's the reason for your trouble, because it might just be that Apple didn't have suitable 16GB sticks to test when that model was introduced. Just sayin'
Janne
Old 04-17-2014, 08:26 AM
Update:
Ok, I went through (like I am a newbie) and checked every single item on this list:
[find by searching]
Avid Knowledge BaseMac Guide - Mac OS X 10.8 Mountain Lion Optimizations and Troubleshooting
Also, I have (just installed) turned off Virus protection when pro tools is on.
Things seem better. I will update with thread when I have more info. Thank you all so far.
Old 05-02-2014, 06:55 PM
Well, this problem is back. Makes no sense.
This thread didn't help:
http://avid.force.com/pkb/articles/e...kbase&filter=0
Also, It has been crashing numerous times today, just closing a session, OR switching playback engine.
I swapped the OWC 16GB Ram back to the mac 8GB ram sticks, numerous times, no change (-9173 and the crashes above).
PT11 with iMac (Late 2012) and Fusion Drive Rohrak Pro Tools 11 7 03-31-2014 06:32 PM
AAE - 9173 cpu overloads in pt11 vs pt10 Carbon 2501 Pro Tools 11 0 03-07-2014 09:22 PM
i7 Macbook Pro - 11.0.2 / 11.0.3 constant -9173 errors A Chapman macOS 13 12-18-2013 09:36 PM
Macbook pro 2012 Jay Omega macOS 2 05-15-2012 10:48 AM
Which is better? (New) MacBook Pro 15 inch or 17 inch Hookshot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 07-21-2009 09:07 PM
