Re: Absurd and arbitrary HDX fan noise
I had been using an HDX1 for about a year and recently added a 2nd card. The fan noise was never an issue until this addition. It seems to kick on about 20 minutes into a session regardless of I/O density or plugin count. As soon as I quit PT the fans turn off.
Hello dwayne,
Our systems are HDX2 and HDX3, perhaps the firmware has an issue with that. Naturally with more than one card there is a higher heat load to deal with. However as noted above, when the fans came on we did thermal scanning of both cards in use and nothing on them, no components, were elevated in temperature. As a part-time circuit designer I know thermal parameters pretty well. The firmware is simply not programmed correctly and should be corrected. Hugh |
It is my understanding that the first (pre release) HDX cards has NO fan.
So I am thinking of disconnecting the 2nd HDX card for the next few months while I am in editing mode as I don't really need it until our large 7.1 stems come into play. Do I need to take out the card or can I simply disconnect the link and power cables from card 1 to card 2?
The fans are just too loud in my cutting room. |
And yes... the fans are THAT LOUD.
#16
Whaaaattt diiidd yoooouuuuu saaayyyyy?????
#17
#18
Pete |
#19
Rather than up an older thread or start a new one - I figured this thread and my enquiry are on point enough...
On the verge of going HDX here from HDN... Can I get some input here on noise levels for a lightly used HDX1 in a Sonnet Echo III? I have a project studio and unfortunately no machine room but can at least get the Echo III about 5 feet away and closer to floor level in a rack. I HATE fan noise and currently the AVID 16X16 with Silenx fan upgrade is the only thing I hear in my room (only other fan is nMP). Comments on the current state of HDX1 fan noise in Sonnet chassis very much appreciated. Any simple dBA readings at any distance?? Noise level in my room is now 34dBA at operator position and I like it
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
#20
Hey there... my friends have HDX1's in the Sonnet Box. They say the fans rarely come on. The noise will come from the Sonnet itself, if anything. FWIW
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini | Bigpit | Windows | 1 | 09-09-2013 09:26 AM |
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? | PeterGreen | Pro Tools 10 | 24 | 01-23-2013 06:38 AM |
What!!!!??? Absurd Cannot Save Neo Assertion! | Ormond | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-31-2007 09:00 AM |
The removal of the "special offer" is absurd! | jtarbutn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 03-17-2006 07:25 PM |
Attn: Drumkit from Hell experts: noise noise noise | Smelt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 07-30-2003 06:31 AM |
