#41
Re: Kernel Panic with Mbox2 USB
I'm having this problem on new 2008 Macbook Pro 15" when shutting down after unplugging the Mbox2. Just a heads up for those that are interested.
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
#42
Hey, I have the same issue with the Mbox Mini on a 2008 MBP. To be honest, I'm not very happy with the solution of restarting every time I need to unplug my mbox. What's the point of having a portable computer if you can't take it anywhere without shutting it down all the time? As I'm always moving around, I sometimes don't have time to shut down, and so if the mbox is still plugged in, it means I'm going to have a kernel panic while I'm out somewhere! Is there any word on new drivers or a fix for this, because the workaround is not acceptable!
#43
Has anyone else noticed that they have a hanging coreaudiod process in activity monitor? I can force quit and it starts up fine, but then stops responding after about 20 seconds...I'm wondering if this is the issue?
#44
http://duc.digidesign.com/showthread.php?t=194592
mp (8x2,8ghz 8gb) mbp (c2d 2,53ghz 4gb) osx10.6.3 pt8.0.3 mptk2 mbox2 www.myspace.com/pukspace eSoundz name: jus11 |
#45
Probably the worst decision I have made for my Mac was to buy an Mbox. Not only does it hang every other application when plugged IN but gives me Kernel Panic messages when I take it OUT. Glad to see that I'm not just trippin' and this is quite common. I'd make a comment otherwise but I think this thread was informative... Thanks
#46
Re: Kernel Panic with Mbox2 USB -- partially isolated problem
BUT -- I've isolated the problem, to a certain extent: the problem occurs when quiting Safari or QuickTime. Since I always have at least Safari running just before shutting down, I used to think that the problem was in shutting down. However, if, after quitting Pro Tools (after at least 20 minutes of usage), and after then going into System Preferences -> Sound and making sure that "Line Out", rather than Mbox 2 is selected -- if at that point, I then quit Safari (if it was running too) or quit QuickTime (if it was running too), then the OS crashes, every time. Here are the specs of my system and my version of Pro Tools: Mac Pro, 2 x Intel processors, 6 Gb Ram, running OS 10.4.11 Pro Tools, version 7.4cs7, but with update cs8 (the latest) applied. |
#47
I have had an MBox 2 Pro for a while and never had any problems. I started using an MBox micro a few days ago and have had 5 kernel crashes. Digi output isnt selected in system prefs. The crash seems to happen about 15 min after I pull the Micro from the USB port.
MacBookPro 2.5, 2GB Ram PT LE 8 cs2 Micro MBox Pro no other apps open an progress on this problem????
HF |
#48
I have the same problem with the mbox micro. my computer crashes when I go to shut down or put the computer to sleep after using the micro. Even if pro-tools has been closed for hours and I go to shut down, it still happens.
I'm using a macbook pro (2.4 Ghz Intel Core 2 Duo) 4 GB RAM. I have PT LE 8.0, but it did the same in version 7.4.3 as well. This happens EVERY TIME I use the mbox 2 micro. Pro-Tools works great, it's only when I go to shut down. IT'S ANNOYING THE BALLS OFF ME. |
#49
Don't disconnect the Mbox from the computer while the computer is still on.
#50
Constant Kernel Panic, Mbox2 Micro, 10.6.2 | cablenaute | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-09-2010 08:37 PM |
Mbox 2 Mini causes Kernel Panic after 8 months of no issues. Panic Report Included... | oneakmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-09-2010 08:52 AM |
Kernel Panic with 003 | DSwartz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-04-2010 10:48 AM |
MBox2 Kernel Panic on Leopard, Anyone? | products7074740 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-10-2008 09:27 PM |
Kernel Panic | Jon Thomas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-23-2005 10:55 PM |
